1506A 0011000
1506A 0011000
    BELDEN
    #20 FFEP SH FLMRST
1506A 0011000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1506A Coax - RG-59/U Type For more Information please call 1-800-Belden1 General Description: 20 AWG solid .032" bare copper conductor, plenum, foam FEP insulation, Duofoil® + tinned copper braid shield (95% coverage), Flamarrest® jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 20 Solid BC - Bare Copper .032 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Trade Name Insulation Material Teflon® Dia. (in.) FFEP - Foam Fluorinated Ethylene Propylene .133 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 2 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.196 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 29 lbs/1000 ft. Max. Recommended Pulling Tension: 68 lbs. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1506A Coax - RG-59/U Type Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 1505A Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.097 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.1 Nominal Velocity of Propagation: VP (%) 84 Nominal Delay: Delay (ns/ft) 1.21 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.2 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.290 3.580 0.620 5.000 0.700 7.000 0.820 10.000 1.050 67.500 2.200 71.500 2.250 100.000 2.700 135.000 3.200 143.000 3.250 180.000 3.650 270.000 4.550 360.000 5.250 540.000 6.400 720.000 7.300 750.000 7.500 1000.000 9.000 1500.000 11.300 2250.000 14.400 3000.000 17.200 Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: Impedance tested in accordance with ASTM D-4566 paragraph 48.2, option 2 using a 75 Ohm fixed bridge and termination. Other Electrical Characteristic 2: Return Loss tested in accordance with ASTM D-4566 paragraph 50.3, using a 75 Ohm fixed bridge and termination. Minimum Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1506A Coax - RG-59/U Type 5.000 1600.000 23.000 1600.000 4500.000 21.000 Sweep Test Sweep Testing: 100% Sweep tested 5 MHz to 3 GHz. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1506A N3U1000 1,000 FT 31.000 LB GREEN, MIL CZ #20 FFEP SH FLMRST 1506A 0011000 1,000 FT 31.000 LB BROWN CZ #20 FFEP SH FLMRST 1506A 0021000 1,000 FT 31.000 LB RED CZ #20 FFEP SH FLMRST 1506A 0031000 1,000 FT 31.000 LB ORANGE Z #20 FFEP SH FLMRST 1506A 0041000 1,000 FT 31.000 LB YELLOW Z #20 FFEP SH FLMRST 1506A 0061000 1,000 FT 31.000 LB BLUE, LIGHT CZ #20 FFEP SH FLMRST 1506A 0071000 1,000 FT 31.000 LB VIOLET CZ #20 FFEP SH FLMRST 1506A 0081000 1,000 FT 31.000 LB GRAY Z #20 FFEP SH FLMRST 1506A 0101000 1,000 FT 31.000 LB BLACK C #20 FFEP SH FLMRST 1506A 010500 500 FT 16.500 LB BLACK CZ #20 FFEP SH FLMRST 1506A 8771000 1,000 FT 31.000 LB NATURAL C #20 FFEP SH FLMRST 1506A 877500 500 FT 16.500 LB NATURAL CZ #20 FFEP SH FLMRST Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 6 Revision Date: 06-17-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1506A 0011000 价格&库存
很抱歉,暂时无法提供与“1506A 0011000”相匹配的价格&库存,您可以联系我们找货
1506A 0011000
  • 1000+41.177451000+5.33392
