1624R F2V1000
1624R F2V1000
    BELDEN
    CAT5 4PR F/UTP CMR REEL
1624R F2V1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1624R Multi-Conductor - Category 5 Nonbonded-Pair ScTP Cable For more Information please call 1-800-Belden1 General Description: CAT5 (100MHz), 4-Pair, F/UTP-Foil shielded, Riser-CMR, Premise Horizontal Cable, 24 AWG solid bare copper conductors, Polyolefin insulation, Beldfoil® shield, ,PVC jacket, RJ-45 compatible Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU Digital Audio, AES51, RS-422, 100MHz Category 5 Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.260 Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White /Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 30 lbs/1000 ft. Max. Recommended Pulling Tension: 25 lbs. Min. Bend Radius/Minor Axis: 1 in. Min. Bend/Installation: 2.600 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR, UL444 CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1624R Multi-Conductor - Category 5 Nonbonded-Pair ScTP Cable EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: NEMA WC-63.1 Category 5 Flame Test UL Flame Test: UL1666 Riser CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1624P Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 300 Nominal Velocity of Propagation: VP (%) 67 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 45 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.38 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Elelctricals: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. SRL (dB) Fitted Imp. (Ohms) 1 2.0 62.2 62.3 23.0 100 ± 15% 4 4.1 53.3 53.3 23.0 100 ± 15% 8 5.8 48.8 48.8 23.0 100 ± 15% 10 6.5 47.3 47.3 23.0 100 ± 15% 16 8.2 44.3 44.3 23.0 100 ± 15% 20 9.3 42.8 42.8 23.0 100 ± 15% 25 10.4 41.3 41.3 22.0 100 ± 15% 31.25 11.7 39.9 39.9 21.1 100 ± 15% 62.5 17.0 35.4 35.4 18.0 100 ± 15% 100 22.0 32.2 32.3 16.0 100 ± 15% Notes (Overall) Notes: Shield is bonded to jacket inner wall for electrical stability. RJ-45 Compatible. Jacket sequentially marked at 2 ft. intervals. Third party verified to TIA/EIA-568-B.2, Category 5. Put Ups and Colors: Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1624R Multi-Conductor - Category 5 Nonbonded-Pair ScTP Cable Item # Putup Ship Weight Color Notes Item Desc 1624R B02A1000 1,000 FT 36.000 LB PURPLE CZ CAT5 4PR F/UTP CMR RIB 1624R B021000 1,000 FT 33.000 LB PURPLE CZ CAT5 4PR F/UTP CMR REEL 1624R F2VA1000 1,000 FT 36.000 LB GRAY, DEC CZ CAT5 4PR F/UTP CMR RIB 1624R F2V1000 1,000 FT 33.000 LB GRAY, DEC CZ CAT5 4PR F/UTP CMR REEL 1624R F2V1640 1,640 FT 54.120 LB GRAY, DEC Z CAT5 4PR F/UTP CMR REEL 1624R 002A1000 1,000 FT 36.000 LB RED CZ CAT5 4PR F/UTP CMR RIB 1624R 0021000 1,000 FT 33.000 LB RED CZ CAT5 4PR F/UTP CMR REEL 1624R 003A1000 1,000 FT 36.000 LB ORANGE CZ CAT5 4PR F/UTP CMR RIB 1624R 0031000 1,000 FT 33.000 LB ORANGE CZ CAT5 4PR F/UTP CMR REEL 1624R 004A1000 1,000 FT 36.000 LB YELLOW CZ CAT5 4PR F/UTP CMR RIB 1624R 0041000 1,000 FT 33.000 LB YELLOW CZ CAT5 4PR F/UTP CMR REEL 1624R 005A1000 1,000 FT 36.000 LB GREEN, DARK CZ CAT5 4PR F/UTP CMR RIB 1624R 0051000 1,000 FT 33.000 LB GREEN, DARK CZ CAT5 4PR F/UTP CMR REEL 1624R 006A1000 1,000 FT 36.000 LB BLUE, LIGHT CZ CAT5 4PR F/UTP CMR RIB 1624R 0061000 1,000 FT 33.000 LB BLUE, LIGHT CZ CAT5 4PR F/UTP CMR REEL Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 3 Revision Date: 08-14-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
1624R F2V1000 价格&库存
很抱歉,暂时无法提供与“1624R F2V1000”相匹配的价格&库存,您可以联系我们找货
