179DT N3U1000
179DT N3U1000
    BELDEN
    #28H PE/GIFPE SH PVC
179DT N3U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 179DT Coax - Sub-Miniature For more Information please call 1-800-Belden1 General Description: 28.5 AWG solid .012" bare copper conductor, gas-injected foam HDPE insulation, Duofoil® foil + tinned copper braid shield (95% coverage), PVC jacket. Usage (Overall) Suitable Applications: Broadcast Mobil Trucks, Digital Video, Precision Video, Telecommunications Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 28.5 Solid BC - Bare Copper .0122 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .056 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.100 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 8 lbs/1000 ft. Max. Recommended Pulling Tension: 18 lbs. Min. Bend Radius/Minor Axis: 1 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 179DT Coax - Sub-Miniature MII Order #39 (China RoHS): Yes RG Type: 179/U Flame Test UL Flame Test: UL1666 Vertical Shaft Suitability Suitability - Indoor: Yes Suitability - Outdoor: No Suitability - Aerial: No Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .106 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.4 Nominal Velocity of Propagation: VP (%) 77 Nominal Delay: Delay (ns/ft) 1.32 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 70.500 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 8.000 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 1.180 5.000 1.850 6.000 1.990 7.000 2.150 10.000 2.390 12.000 2.500 67.500 5.300 71.500 5.500 88.500 6.000 100.000 6.400 135.000 7.200 143.000 7.500 180.000 8.300 270.000 10.200 360.000 11.800 540.000 14.600 720.000 17.000 750.000 17.400 1000.000 20.200 1500.000 24.800 2000.000 28.900 2250.000 30.900 3000.000 35.900 4500.000 45.000 Max. Operating Voltage - UL: Voltage 300 V RMS Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 179DT Coax - Sub-Miniature Other Electrical Characteristic 1: Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge and termination. 75 +/- 3 Ohms Other Electrical Characteristic 2: Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, using a 75 Ohm fixed bridge and termination. Minimum Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5 1600 23 1600 4500 21 Sweep Test Sweep Testing: 100% Sweep tested 5 MHz to 4.5 GHz. Misc. Information (Overall) Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 179DT N3U1000 1,000 FT 9.000 LB GREEN, MIL C #28H PE/GIFPE SH PVC 179DT 0011000 1,000 FT 9.000 LB BROWN 179DT 0021000 1,000 FT 9.000 LB RED C #28H PE/GIFPE SH PVC 179DT 0031000 1,000 FT 9.000 LB ORANGE C #28H PE/GIFPE SH PVC 179DT 0041000 1,000 FT 9.000 LB YELLOW C #28H PE/GIFPE SH PVC 179DT 0061000 1,000 FT 9.000 LB BLUE, LIGHT 179DT 0071000 1,000 FT 9.000 LB VIOLET 179DT 0081000 1,000 FT 9.000 LB GRAY 179DT 0091000 1,000 FT 9.000 LB WHITE #28H PE/GIFPE SH PVC 179DT 0101000 1,000 FT 9.000 LB BLACK #28H PE/GIFPE SH PVC 179DT 010500 500 FT 4.500 LB BLACK #28H PE/GIFPE SH PVC #28H PE/GIFPE SH PVC #28H PE/GIFPE SH PVC #28H PE/GIFPE SH PVC C #28H PE/GIFPE SH PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 12 Revision Date: 06-17-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
179DT N3U1000 价格&库存
很抱歉,暂时无法提供与“179DT N3U1000”相匹配的价格&库存,您可以联系我们找货
