19206 010250
19206 010250
    BELDEN
    CBL 3COND 12AWG EPDM
19206 010250 数据手册
Part Number: 19206 Portable Cordage, (3) 12 AWG (65x30) BC, EPDM/Rubber, Type SO Product Description Three 12 AWG stranded (65x30) bare copper conductors, EPDM insulation, rubber jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 12 65x30 Material No. of Conductors BC - Bare Copper 3 Conductor Count: 3 AWG Size: 12 Insulation Material Nominal Wall Thickness EPDM - Ethylene Propylene Diene Monomer Rubber 0.051 in Color Chart Color Black White Green Outer Shield Material Material Unshielded Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness Separator Material Rubber 0.632 in 0.1 in Paper Tape Construction and Dimensions Type of Cordage: SO Stranding Lay Length Black mm Cabling Filler Jute Electrical Characteristics Current Max. Recommended Current [A] 25 Amps per conductor @ 25°C; 18 Amps per conductor @ 25°C over 50 ft 18 Amps per conductor @ 25°C over 50 ft. Voltage Dielectric Withstand Voltage UL Voltage Rating 3000 V AC Applired For 1 Min. 600V RMS Electrical Characteristics Notes: Dielectric Withstand Voltage: 3000 V AC Applired For 1 Min Temperature Range UL Temp Rating: 90°C Mechanical Characteristics Oil Resistance: Yes Bulk Cable Weight: 231 lbs/1000ft Min Bend Radius/Minor Axis: 6.5 in Standards NEC/(UL) Specification: SO CSA AWM Specification: SO Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Part Number Plenum (Y/N): No Variants Item # Color Footnote 19206 010250 BLACK C F Footnote: C - CRATE REEL PUT-UP. Footnote: F - MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50'. Product Notes Notes: Overall Cabling Separator Material: Paper Tape © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
19206 010250 价格&库存
很抱歉,暂时无法提供与“19206 010250”相匹配的价格&库存,您可以联系我们找货
