3073F C551000
3073F C551000
    BELDEN
    CBL 1PR 18AWG SHLD
3073F C551000 数据手册
Part Number: 3073F DataTray®, (1 pr) 18 AWG (7x26) TC, FRPO/PVC, Foil+TC Braid Shld, CMG, TC/PLTC/ITC, 100Ω Product Description One 18 AWG pair stranded (7x26) tinned copper conductors, flame-retardant polyolefin insulation, overall Beldfoil® (100% coverage) plus a tinned copper braid shield (55% coverage), UV-resistant PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 18 7x26 Material Nominal Diameter No. of Pairs TC - Tinned Copper 0.046 in 1 Conductor Count: 2 Total Number of Pairs: 1 AWG Size: 18 Insulation Material Nominal Diameter Nominal Wall Thickness FRPO - Flame Retardant Polyolefin 0.128 in 0.041 in Color Chart Number Color 1 Natural 2 Blue Outer Shield Material Type Layer Material Tape 1 Aluminum Foil-Polyester Tape Braid 2 TC - Tinned Copper Material Trade Name Coverage [%] Drainwire Material Beldfoil® 100 % 55 % Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.388 in 0.053 in Construction and Dimensions Stranding Diameter 0.246 mm Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 6.9 Ohm/1000ft Capacitance Nom.Mutual Capacitance 15.3 pF/ft 2.9 Ohm/1000ft Drainwire Diameter Drainwire AWG Drainwire Construction n x D TC - Tinned Copper 0.036 in 20 7x28 mm Inductance Nominal Inductance 0.15 µH/ft Impedance Nominal Characteristic Impedance 100 Ohm High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.41 dB/100ft 10 MHz 1.33 dB/100ft 50 MHz 2.97 dB/100ft 100 MHz 4.2 dB/100ft 200 MHz 5.95 dB/100ft 400 MHz 7.52 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.58 ns/ft 64.5 % High Freq Frequency [MHz] 1 MHz 10 MHz 50 MHz 100 MHz 200 MHz 400 MHz Voltage UL Voltage Rating 600V RMS (NEC Type TC) Electrical Characteristics Notes: Mutual Capacitance: 15.3 pF/ft Temperature Range UL Temp Rating: 75°C Dry Operating Temp Range: -40°C To +75°C Mechanical Characteristics Bulk Cable Weight: 61 lbs/1000ft Max Recommended Pulling Tension: 90 lbs Min Bend Radius/Minor Axis: 4 in Standards NEC/(UL) Specification: CMG, PLTC, ITC, TC CEC/C(UL) Specification: CMG Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-10-13 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Sunlight Resistance: Yes Flammability, LS0H, Toxicity Testing C(UL) Flammability: FT1, FT4 UL Flammability: UL1685 UL Loading CSA Flammability: FT1, FT4 Part Number Plenum (Y/N): No Variants Item # Color Footnote 3073F C551000 BLUE, CAIRO C 3073F C555000 BLUE, CAIRO C N Footnote: C - CRATE REEL PUT-UP. Footnote: N - FINAL PUT-UP LENGTH MAY VARY -0% TO +10% FROM LENGTH SHOWN. Product Notes Notes: CPE Jacket Optional. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
3073F C551000 价格&库存
很抱歉,暂时无法提供与“3073F C551000”相匹配的价格&库存,您可以联系我们找货
