3084F T5U500
3084F T5U500
    BELDEN
    CBL 1PR/22AWG 1PR/24AWG SH
3084F T5U500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3084F Multi-Conductor - DeviceBus® for ODVA DeviceNet™ For more Information please call 1-800-Belden1 General Description: 22 and 24 AWG stranded tinned copper conductors, PVC insulation (power), FPE insulation (Data), individually foil shielded (100% coverage) and an overall tinned copper braid (65% coverage), sunlight/oil-resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors # Pairs AWG Stranding Conductor Material 4 1 22 155x44 TC - Tinned Copper 1 24 105x44 TC - Tinned Copper Insulation Insulation Material: Insulation Material AWG PVC - Polyvinyl Chloride 22 FPE - Foam Polyethylene 24 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material Coverage (%) 22 AWG Pair Beldfoil® Tape Aluminum Foil-Polyester Tape 100 24 AWG Pair Beldfoil® Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 22 Inner Shield Drain Wire Stranding: 26x36 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 65 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.275 in. Pair Pair Color Code Chart: Number Color 22 AWG Pair Red & Black 24 AWG Pair Blue & White Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 41 lbs/1000 ft. Max. Recommended Pulling Tension: 65 lbs. Min. Bend Radius/Minor Axis: 2.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3084F Multi-Conductor - DeviceBus® for ODVA DeviceNet™ CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: ODVA Class 2 Thin Flame Test UL Flame Test: UL1685 FT4 Loading CSA Flame Test: FT4 Suitability Sunlight Resistance: Yes Oil Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Description Impedance (Ohm) 24 AWG Pair 120 Nom. Capacitance Conductor to Conductor: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Capacitance (pF/ft) 24 AWG Pair 1 12.0 Nominal Velocity of Propagation: Description VP (%) 24 AWG Pair 75 Maximum Delay: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Delay (ns/ft) 24 AWG Pair 1.36 Maximum Conductor DC Resistance: Description DCR @ 20°C (Ohm/100 m) 22 AWG 17.5 24 AWG 28.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.2 Max. Attenuation: () Description Freq. (MHz) .29 24 AWG Pair Only .125 .50 .500 .70 1.000 Max. Operating Voltage - UL: Voltage Description 300 V RMS CL2, CMG 300 V RMS C(UL) AWM Max. Recommended Current: Current 1.7 Amps per conductor @ 25°C (24 AWG) 4 Amps per conductor @ 24 V per NEC CL2 (Power Pair) Notes (Overall) Notes: Hi-Flex. Thin. Flex Test Results: "S-Bend" Flex Test - 4" Diameter Wheels, 2 lbs. tension: 150, 000 Cycles Averaged. +/-90 Degree Flex Test: 2" Diameter, 2 lbs. tension 8500 Cycles Averaged. Flex tests were conducted at less than the recommeded cable minimum bend radius. Actual cable performance will depend on the individual application. Meter marks on jacket to aid users in installation. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3084F Multi-Conductor - DeviceBus® for ODVA DeviceNet™ Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 3084F T5U1000 1,000 FT 45.000 LB GRAY T5U C 2 #22, 2 #24 SH PVC 3084F T5U2000 2,000 FT 90.000 LB GRAY T5U C 2 #22, 2 #24 SH PVC 3084F T5U500 500 FT 22.000 LB GRAY T5U CN 2 #22, 2 #24 SH PVC 3084F T5U5000 5,000 FT 220.000 LB GRAY T5U CZ 2 #22, 2 #24 SH PVC Notes: C = CRATE REEL PUT-UP. N = FINAL PUT-UP LENGTH MAY VARY -0% TO +10% FROM LENGTH SHOWN. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 1 Revision Date: 08-17-2011 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
3084F T5U500 价格&库存
很抱歉,暂时无法提供与“3084F T5U500”相匹配的价格&库存,您可以联系我们找货
