32418 010500
32418 010500
    BELDEN
    HOOK-UP STR 18AWG
32418 010500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 32418 Hook-up/Lead - UL AWM Style 3071 For more Information please call 1-800-Belden1 General Description: The glass braid offers abrasion resistance, is treated to prevent fraying.The Silicone insulation strips easy and clean.Recommended for high-temperature applications in motors, lighting fixtures, clothes dryers, stoves, therapeutic and electronic devices Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 18 7x26 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Silicone with Lacquered Glass Braid Covering .030 Overall Insulation Overall Cable Overall Nominal Diameter: 0.133 in. Mechanical Characteristics (Overall) UL Temperature Rating: 200°C (UL AWM Style 3071) Bulk Cable Weight: 15 lbs/1000 ft. Recommended Maximum Baking Cycles: 24 hours @ 410°F (210°C) Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL AWM Style: UL Style 3071 (600 V 200°C) UL Rating: 600 V, 200°C, VW-1 CSA Rating: 600 V, 200°C CSA Type: SEW-2 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.200 Max. Operating Voltage - UL: Voltage Description Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 32418 Hook-up/Lead - UL AWM Style 3071 600V AWM 3071 Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 32418 009500 500 FT 6.500 LB WHITE F #18 SIL GL BRD 200C 600V 32418 0096000 6,000 FT 72.000 LB WHITE CIZ #18 SIL GL BRD 200C 600V 32418 010500 500 FT 6.500 LB BLACK F #18 SIL GL BRD 200C 600V 32418 0106000 6,000 FT 72.000 LB BLACK CIZ #18 SIL GL BRD 200C 600V Notes: C = CRATE REEL PUT-UP. F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50' I = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 200' Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 1 Revision Date: 05-04-2015 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
32418 010500 价格&库存
很抱歉,暂时无法提供与“32418 010500”相匹配的价格&库存,您可以联系我们找货
