Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
35616 Hook-up/Lead - UL AWM Style 3173 - XL-DUR®
For more Information
please call
1-800-Belden1
General Description:
The insulation is cross-linked polyethylene applied in a single extrusion. This construction has excellent
thermal aging characteristics, moisture resistance, and solvent resistance. The 356-series of XL-DUR is
recommended for class 130(B)as motor leads
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
16
26x30
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Min. Avg. Wall (in.)
XLPE - Cross Linked Polyethylene 0.030
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.122 in.
Mechanical Characteristics (Overall)
Bulk Cable Weight:
14 lbs/1000 ft.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
600 V, 125°C
CSA Rating:
600 V, 125°C
CSA Type:
CL1251
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
07/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
4.000
Max. Operating Voltage - UL:
Voltage
600 V
Max. Recommended Current:
Description
Current
Single conductor in free air @ 30C ambient 28 amps
Page 1 of 2
08-26-2016
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
35616 0015000
5,000 FT
75.000 LB
BROWN
CIUZ
#16STR XLPE 125C 600VBRN
35616 002500
500 FT
7.500 LB
RED
F
#16 STR XLPE 125C 600V
35616 0025000
5,000 FT
75.000 LB
RED
CIUZ
35616 0035000
5,000 FT
75.000 LB
ORANGE
CIUZ
#16STR XLPE 125C 600VORG
35616 0045000
5,000 FT
75.000 LB
YELLOW
CIUZ
#16STR XLPE 125C 600VYEL
35616 005500
500 FT
7.500 LB
GREEN, DARK
F
35616 0055000
5,000 FT
75.000 LB
GREEN, DARK
CIUZ
#16STRXLPE 125C 600VDGRN
35616 0065000
5,000 FT
75.000 LB
BLUE, LIGHT
CIUZ
#16STRXLPE 125C 600VLBLU
35616 009500
500 FT
7.500 LB
WHITE
F
35616 010500
500 FT
7.500 LB
BLACK
F
35616 0105000
5,000 FT
75.000 LB
BLACK
CIUZ
#16STR XLPE 125C 600VBLK
Notes:
C = CRATE REEL PUT-UP.
F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50'
I = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 200'
U = TOPCOAT ADDERS ON STOCK SOLID COLORS. MINIMUM ORDER 10000' PER COLORCOMBINATION. (SEE TOPCOAT ADDER TABLE)
Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN.
Revision Number: 1
Revision Date: 09-04-2015
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“35616 0015000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+7.856575000+1.00896
