37118 0025000
37118 0025000
    BELDEN
    HOOK-UP STR 18AWG EPDM
37118 0025000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 37118 Hook-up/Lead - UL AWM Style 3340 and 3374 For more Information please call 1-800-Belden1 General Description: EPDM high temperature lead wire. 150ºC EPDM wire is recommended for Class 130(B), 155(F) and also in some 180(H) systems. It^s UL Recognized under Style 3374 as 150ºC-600V Appliance Wiring Material. The CSA Listing, as a coil lead, is 125ºC, 600V. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 18 16x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Min. Avg. Wall (in.) EPDM - Ethylene Propylene Diene Monomer Rubber 0.045 Overall Insulation Overall Cable Overall Nominal Diameter: 0.141 in. Mechanical Characteristics (Overall) UL Temperature Rating: 125°C (UL AWM Style 3340), 125°C (UL AWM Style 3374), 150°C Bulk Cable Weight: 12.750 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 600 V, 150°C CSA Rating: 600 V, 125°C CSA Type: CL1254 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.000 Max. Operating Voltage - UL: Voltage 600 V RMS (UL AWM Style 3340) 600 V RMS (UL AWM Style 3374) Max. Recommended Current: Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 37118 Hook-up/Lead - UL AWM Style 3340 and 3374 Description Current Single conductor in free air @ 30C ambient 24 amps Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 37118 002500 500 FT 7.500 LB RED F #18 STR EPDM 150C 600V 37118 0025000 5,000 FT 70.000 LB RED CIZ #18STR EPDM 150C 600VRED 37118 005500 500 FT 7.500 LB GREEN, DARK F #18STREPDM150C600VDGRN 37118 009500 500 FT 7.500 LB WHITE F #18 STR EPDM 150C 600V 37118 0095000 5,000 FT 70.000 LB WHITE CIZ #18STR EPDM 150C 600VWHT 37118 010500 500 FT 7.500 LB BLACK F #18 STR EPDM 150C 600V 37118 0105000 5,000 FT 70.000 LB BLACK CIZ #18STR EPDM 150C 600VBLK 37118 0135000 5,000 FT 70.000 LB BLUE, DARK CIZ #18STREPDM 150C 600VDBLU Notes: C = CRATE REEL PUT-UP. F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50' I = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 200' Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 1 Revision Date: 03-20-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
37118 0025000 价格&库存
很抱歉,暂时无法提供与“37118 0025000”相匹配的价格&库存,您可以联系我们找货
