5GCSY-K100
5GCSY-K100
    BELDEN
    BELDEN - 5GCSY-K100 - Multicore Cable, Screened, 5 Core, 1 mm², 328 ft, 100 m
5GCSY-K100 数据手册
MachFlex 350 SY Cables Armored (SY) PVC Control Cables Galvanized Steel Wire Braid (GSWB) Excellent Mechanical Protection Applications Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more. General Reference Standards • • • • DIN VDE 0295, IEC 60228, BS6360 DIN EN 50290-2-22, DIN VDE 0207-363-4-1 DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 RoHS & REACH & CE Directives Construction and Performance 1. Conductor Material Stranded bare copper (DIN VDE 0295 Class 5) 2. Insulation Material & Color Insulation Material & Colour PVC (polyvinyl chloride). A) All black color with number coding = without protective conductor. B) Black color with number coding plus 1 green & yellow = with protective conductor. 3. Braid Shield Material GSWB (Galvanized Steel Wire Braid) 4. Jacket / Sheath Material PVC (polyvinyl chloride) 5. Flame Retardancy VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 6. Voltage Rating (Uo/U) 300 / 500 V 7. Oil Resistant DIN EN 50290-2-22 (TM54) 8. Temperature Range -30 °C TO +70 °C (Occasional movement) -40 °C TO +80 °C (Fixed installation) 9. Bending Radius 20 x OD (Occasional movement) 6 x OD (Fixed installation) 10. Other Properties Good UV resistance, chemical resistance & flexibility MachFlex 350 SY Armored (SY) PVC Control Cables GALVANIZED STEEL WIRE BRAID SHIELD (GSWB) CABLE WITH (G) PROTECTIVE GROUND 5 4 3 2 1 = Conductor 2 = Insulation 3 = Inner Sheath 4 = Galvanized Steel Wire Braid Shield 5 = Outer Sheath 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.5 8.0 8.5 9.1 11.4 13.9 Conductor 0.75 mm2 Copper Weight (kg/km) 14.40 19.20 24.00 33.60 58.00 96.70 EMEA Part Code 3GASY 4GASY 5GASY 7GASY 12GASY 20GASY APAC Part Code 3G0.5SY 4G0.5SY 5G0.5SY 7G0.5SY 12G0.5SY 20G0.5SY Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 8.0 8.6 9.2 9.9 12.4 15.2 Copper Weight (kg/km) 21.60 28.80 36.00 50.00 86.00 143.30 EMEA Part Code 3GBSY 4GBSY 5GBSY 7GBSY 12GBSY 20GBSY APAC Part Code 3G0.75SY 4G0.75SY 5G0.75SY 7G0.75SY 12G0.75SY 20G0.75SY Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.4 28.80 4 9.1 38.40 5 9.8 48.00 7 10.5 67.00 12 13.3 115.00 20 16.3 192.00 Conductor 2.50 mm2 EMEA Part Code 3GCSY 4GCSY 5GCSY 7GCSY 12GCSY 20GCSY APAC Part Code 3G1.0SY 4G1.0SY 5G1.0SY 7G1.0SY 12G1.0SY 20G1.0SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 9.0 43.00 4 9.7 58.00 5 10.5 72.00 7 11.3 101.00 12 14.6 173.00 20 17.7 288.30 Conductor 4.00 mm2 EMEA Part Code 3GDSY 4GDSY 5GDSY 7GDSY 12GDSY 20GDSY APAC Part Code 3G1.5SY 4G1.5SY 5G1.5SY 7G1.5SY 12G1.5SY 20G1.5SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 11.0 72.00 4 11.9 96.00 5 12.9 120.00 7 14.2 168.00 12 18.4 288.00 20 22.6 480.00 Conductor 6.00 mm2 EMEA Part Code 3GESY 4GESY 5GESY 7GESY 12GESY 20GESY APAC Part Code 3G2.5SY 4G2.5SY 5G2.5SY 7G2.5SY 12G2.5SY 20G2.5SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 12.6 115.00 4 13.9 154.00 5 15.1 192.00 7 16.4 269.00 9 19.9 345.90 12 21.5 461.00 Conductor 10.00 mm2 EMEA Part Code 3GFSY 4GFSY 5GFSY 7GFSY 9GFSY 12GFSY APAC Part Code 3G4SY 4G4SY 5G4SY 7G4SY 9G4SY 12G4SY No. of Cores 3 4 5 7 9 EMEA Part Code 3GGSY 4GGSY 5GGSY 7GGSY 9GGSY APAC Part Code 3G6SY 4G6SY 5G6SY 7G6SY 9G6SY No. of Cores 3 4 5 7 9 EMEA Part Code 3GHSY 4GHSY 5GHSY 7GHSY 9GHSY APAC Part Code 3G10SY 4G10SY 5G10SY 7G10SY 9G10SY EMEA Part Code 3GJSY 4GJSY 5GJSY 7GJSY APAC Part Code 3G25SY 4G25SY 5G25SY 7G25SY Nom. Overall Diameter (mm) 14.9 16.2 17.7 19.3 23.5 Copper Weight (kg/km) 172.80 230.00 288.00 403.00 518.10 Conductor 16.00 mm2 No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 21.4 23.6 26.1 28.4 Copper Weight (kg/km) 460.50 614.00 768.00 1,075.00 Nom. Overall Diameter (mm) 18.0 19.8 21.7 23.7 29.1 Copper Weight (kg/km) 288.00 384.00 480.00 672.00 864.00 Conductor 25.00 mm2 EMEA Part Code 3GISY 4GISY 5GISY 7GISY APAC Part Code 3G16SY 4G16SY 5G16SY 7G16SY No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 25.9 28.6 31.2 33.9 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 720.00 960.00 1,200.00 1,680.00 MachFlex 350 SY Armored (SY) PVC Control Cables GALVANIZED STEEL WIRE BRAID SHIELD (GSWB) CABLE WITHOUT (G) PROTECTIVE GROUND 5 4 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.5 8.0 8.5 9.1 11.4 13.9 1 = Conductor 2 = Insulation 3 = Inner Sheath 4 = Galvanized Steel Wire Braid Shield 5 = Outer Sheath Conductor 0.75 mm2 Copper Weight (kg/km) 14.40 19.20 24.00 33.60 58.00 96.70 EMEA Part Code 3XASY 4XASY 5XASY 7XASY 12XASY 20XASY APAC Part Code 3X0.5SY 4X0.5SY 5X0.5SY 7X0.5SY 12X0.5SY 20X0.5SY Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 8.0 8.6 9.2 9.9 12.4 15.2 Copper Weight (kg/km) 21.60 28.80 36.00 50.00 86.00 143.30 EMEA Part Code 3XBSY 4XBSY 5XBSY 7XBSY 12XBSY 20XBSY APAC Part Code 3X0.75SY 4X0.75SY 5X0.75SY 7X0.75SY 12X0.75SY 20X0.75SY Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.4 28.80 4 9.1 38.40 5 9.8 48.00 7 10.5 67.00 12 13.3 115.00 20 16.3 192.00 Conductor 2.50 mm2 EMEA Part Code 3XCSY 4XCSY 5XCSY 7XCSY 12XCSY 20XCSY APAC Part Code 3X1.0SY 4X1.0SY 5X1.0SY 7X1.0SY 12X1.0SY 20X1.0SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 9.0 43.00 4 9.7 58.00 5 10.5 72.00 7 11.3 101.00 12 14.6 173.00 20 17.7 288.30 Conductor 4.00 mm2 EMEA Part Code 3XDSY 4XDSY 5XDSY 7XDSY 12XDSY 20XDSY APAC Part Code 3X1.5SY 4X1.5SY 5X1.5SY 7X1.5SY 12X1.5SY 20X1.5SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 11.0 72.00 4 11.9 96.00 5 12.9 120.00 7 14.2 168.00 12 18.4 288.00 20 22.6 480.00 Conductor 6.00 mm2 EMEA Part Code 3XESY 4XESY 5XESY 7XESY 12XESY 20XESY APAC Part Code 3X2.5SY 4X2.5SY 5X2.5SY 7X2.5SY 12X2.5SY 20X2.5SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 12.6 115.00 4 13.9 154.00 5 15.1 192.00 7 16.4 269.00 9 19.9 345.90 12 21.5 461.00 Conductor 10.00 mm2 EMEA Part Code 3XFSY 4XFSY 5XFSY 7XFSY 9XFSY 12XFSY APAC Part Code 3X4SY 4X4SY 5X4SY 7X4SY 9X4SY 12X4SY No. of Cores 3 4 5 7 9 EMEA Part Code 3XGSY 4XGSY 5XGSY 7XGSY 9XGSY APAC Part Code 3X6SY 4X6SY 5X6SY 7X6SY 9X6SY No. of Cores 3 4 5 7 9 EMEA Part Code 3XHSY 4XHSY 5XHSY 7XHSY 9XHSY APAC Part Code 3X10SY 4X10SY 5X10SY 7X10SY 9X10SY EMEA Part Code 3XJSY 4XJSY 5XJSY 7XJSY APAC Part Code 3X25SY 4X25SY 5X25SY 7X25SY Nom. Overall Diameter (mm) 14.9 16.2 17.7 19.3 23.5 Copper Weight (kg/km) 172.80 230.00 288.00 403.00 518.10 Conductor 16.00 mm2 No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 21.4 23.6 26.1 28.4 Copper Weight (kg/km) 460.50 614.00 768.00 1,075.00 Nom. Overall Diameter (mm) 18.0 19.8 21.7 23.7 29.1 Copper Weight (kg/km) 288.00 384.00 480.00 672.00 864.00 Conductor 25.00 mm2 EMEA Part Code 3XISY 4XISY 5XISY 7XISY APAC Part Code 3X16SY 4X16SY 5X16SY 7X16SY No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 25.9 28.6 31.2 33.9 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 720.00 960.00 1,200.00 1,680.00
5GCSY-K100 价格&库存
很抱歉,暂时无法提供与“5GCSY-K100”相匹配的价格&库存,您可以联系我们找货
5GCSY-K100
  • 1+13.237851+1.71760
  • 25+10.9734825+1.42380
  • 50+9.8413050+1.27690
  • 100+8.70912100+1.13000
库存:25
5GCSY-K100
    • 1+3203.05676
    • 5+3138.99084
    库存:300
