70006E
70006E
    BELDEN
    BELDEN - 70006E - Networking Cable, Profinet, Screened, Cat5e, 22 AWG, 1000 ft, 304.8 m
70006E 数据手册
Profinet Compliant Cables The Belden range of Profinet compliant cables is designed to withstand the entire spectrum of environmental and mechanical hazards, from temperature extremes and sunlight, to solvents, oils, chemicals and moisture. Ordering Information Belden European Item Numbers Jacket Material PVC Premium FRNC PUR (Halogen Free) Electrical Performance Cat 5e Cat 5e Cat 5e Type A Type B Type C (Stationary) 70006E 70006NH 70006PU (Flexible) 70007E 70007NH 70007PU (Trailing) N/A N/A 70008PU Applications • • • • • Industrial environments where IP67 may be required Transmission of data in industrial applications via the Profinet ethernet protocol Type A (stationary) applications, where there is no movement after installation Type B (flexible) applications, subject to occasional movement or vibration after installation Type C (trailing) applications, for instance ‘C Track’ Features & Benefits • Profinet compliant (Type A, B or C) cables with a star quad construction • High shield coverage to maintain signal integrity in the industrial ‘noisy’ environment • Choice of PVC, Premium FRNC or PUR cable jacket for specific application requirements in the harsh industrial environment • Oil resistant • Chemical & solvent resistant • Temperature resistant • Abrasion resistant • Excellent mechanical resistance (especially Type C) • Weld-splatter resistant PUR cable jacket available on request • IP67 rated • Green RAL 6018 cable jacket Construction & Dimensions Mechanical Data Profinet Type A Conductor (22AWG/1 solid bare copper wire) Insulation Filler Bedding Foil & Braid Sheath (Green RAL 6018) Conductor PE Insulation (Nom. Dia.) Bedding Material (Nom. Dia.) Braid Coverage Sheath Material Sheath (Nom. Dia.) 70006E 22AWG/1 1.50mm PVC 3.90mm >85% PVC 6.50mm 70006NH 22AWG/1 1.50mm PVC 3.90mm >85% FRNC 6.50mm 70006PU 22AWG/1 1.50mm PVC 3.90mm >85% PUR 6.50mm Part Number Mechanical Data Profinet Type B Conductor (22AWG/7 7x0.25mm stranded tinned copper) Insulation Filler Bedding Foil & Braid Sheath (Green RAL 6018) Conductor Polyolefin Insulation (Nom. Dia.) Bedding Material (Nom. Dia.) Braid Coverage Sheath Material Sheath (Nom. Dia.) 70007E 22AWG/7 1.55mm PVC 4.00mm >85% PVC 6.50mm 70007NH 22AWG/7 1.55mm PVC 4.00mm >85% FRNC 6.50mm 70007PU 22AWG/7 1.55mm PVC 4.00mm >85% PUR 6.50mm Part Number 2 Mechanical Data – Profinet Type C Conductor (22AWG/19 19x0.15mm stranded tinned copper) Insulation Filler Bedding Foil + Braid Sheath (Green RAL 6018) Part Number 70008PU Conductor Polyolefin Insulation (Nom. Dia.) Bedding Material (Nom. Dia.) Braid Coverage Sheath Material Sheath (Nom. Dia.) 22AWG/19 1.63mm PVC 4.30mm >85% PUR 6.50mm Electrical Properties ISO/IEC 11801 ed. 2.0, Cat5e Max Operating Voltage Test Voltage Max Conductor Resistance @ 20oC Transfer Impedance @ 10 MHz Nominal Velocity of Propagation Delay Impedance @ 1 – 100 MHz Frequency (MHz) 1 4 10 16 31.25 62.5 100 Insertion Loss (dB/100m) 2.1 4 6.3 8 11.4 16.5 21.3 300V RMS 2.5kV DC 57.1 Ohm / km < 40 mOhm / m 68% < 5.3 ns / m 100 +/- 15 Ohm NEXT (dB) 65 56 50 47 43 38 35 ELFEXT (dB/100m) 64 52 44 40 34 28 24 RETURN LOSS (dB) 23 25 25 23.6 21.5 20.1 Mechanical, Physical and/or Environmental Characteristics Flame Resistance Oil Resistance Halogen Free IEC60332-1 IEC 60811-2-1 Bending Radius / Setting Radius IEC 60754-1 / IEC 60754-2 (FRNC and PUR Cable Jacket) 10 x Diameter / 5 x Diameter Temperature Range - Installation Temperature Range - Operating - 5 oC to +50 oC -40 oC to +80 oC Version 04 (02/11) 3
70006E 价格&库存
很抱歉,暂时无法提供与“70006E”相匹配的价格&库存,您可以联系我们找货
