70008PU.01305
70008PU.01305
    BELDEN
    BELDEN - 70008PU.01305 - Networking Cable, DataTuff® Profinet Type C, Quad 2 Pair, Screened, Cat5e, ...
70008PU.01305 数据手册
Part Number: 70008PU DataTuff® PROFINET Cat 5e Type C - Continuous Flexing Cable, Trailing AWM 20549 Product Description PROFINET Category 5e, 2 Pair (Quad), AWG 22 (19), Trailing, Overall Foil+ 85% Braid, PUR No Halogen Outer Jacket Technical Specifications Product Overview Environmental Space: Indoor Physical Characteristics (Overall) Conductor AWG Stranding 22 Stranded Material Construction n x D No. of Conductors TC - Tinned Copper 19x0.15 mm 4 Conductor Count: 4 Total Number of Pairs: 2 Conductor Size: 22 AWG Insulation Material Nominal Diameter Diameter +/- Tolerance PO - Polyolefin 1.63 mm 0.05 mm Color Chart Number Color Quad 1 White & Blue & Yellow & Orange Inner Jacket Material Material Nominal Diameter FRNC / LSZH Bedding 4.3 mm Outer Shield Material Type Material Min. Coverage [%] Tape Aluminum/Polyester Braid TC - Tinned Copper 85 % Outer Jacket Material Material Color Nominal Diameter Diameter +/- Tolerance Separator Material PUR (Halogenfree) Green (RAL 6018) 6.5 mm Construction and Dimensions Cabling Description 1 quad with center filler Electrical Characteristics Conductor DCR Max. Conductor DCR 57.1 Ohm/km 0.2 mm Non-woven foil Shielding: Foil + Braid(s) Impedance Frequency [MHz] Nominal Characteristic Impedance Nominal Characteristic Tolerance 1 - 100 100 Ohm 15 Ohm Delay Max. Delay Nominal Velocity of Propagation (VP) [%] 530 ns/100m 68 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) Min. NEXT [dB] Min. ACRF (ELFEXT) [dB] Min. SRL (Structural Return Loss) 1 MHz 2.1 dB/100m 65 dB 64 dB 4 MHz 4 dB/100m 56 dB 52 dB 23 dB 10 MHz 6.3 dB/100m 50 dB 44 dB 25 dB 16 MHz 8 dB/100m 47 dB 40 dB 25 dB 31.25 MHz 11.4 dB/100m 43 dB 34 dB 23.6 dB 62.5 MHz 16.5 dB/100m 38 dB 28 dB 21.5 dB 100 MHz 21.3 dB/100m 35 dB 24 dB 20.1 dB Transfer Impedance Frequency [MHz] Transfer Impedance 10 Mhz Max. 10 mOhm/m Voltage UL Voltage Rating Voltage Rating [V] 300 V 300 V Temperature Range Installation Temp Range: -5°C To +60°C UL Temp Rating: 80°C Storage Temp Range: -40°C To +80°C Operating Temp Range: -40°C To +80°C Operating Temp Range (Drag Chain Op): -5°C To +60°C Mechanical Characteristics Oil Resistance: IEC 60811-2-1 Torsion Test: Min Number of Torsions: 1000000 Torsion Test: Description: +/- 180° ,12x/min over 1mtr Min No. of Drag Chain Cycles: 5000000 Drag Chain Parameters: a= 3m/s2 v= 3 m/s and r= 60 mm Standards UL AWM Style: UL AWM 20549 ISO/IEC Compliance: ISO/IEC 11801 Ed. 2.2:2002/A2:2010/C1:2011 Data Category: Category 5e Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 Flammability, LS0H, Toxicity Testing CSA Flammability: FT2 Part Number Variants Item # Color 70008PU.011000 Green 70008PU.01305 Green 70008PU.01500 Green 70008PU.01B100 Green Patent: https://www.belden.com/resources/patents History Revision Number: 5 © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
70008PU.01305 价格&库存
很抱歉,暂时无法提供与“70008PU.01305”相匹配的价格&库存,您可以联系我们找货
