Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
73607WS Multi-Conductor - 600V Shielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles
For more Information
please call
1-800-Belden1
General Description:
16 AWG stranded (26x30) bare copper conductors, PVC insulation, oil-resistant PVC inner jacket, tinned
copper braid shield, 85% coverage, oil-resistant overall PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material Dia. (in.)
6
16
26x30
BC - Bare Copper
0.060
Total Number of Conductors:
7
Ground Wire
Ground Wire (Y/N):
Y
Ground Wire AWG:
16
Ground Wire Stranding:
26X30
Ground Wire Conductor Material:
BC - Bare Copper
Ground Wire Insulation Material:
PVC - Polyvinyl Chloride
Insulation
Insulation Material
Wall Thickness (in.) Dia. (in.)
PVC - Polyvinyl Chloride 0.022
0.104
Insulation Color Code Chart:
Color Description
Black Individually Numbered
Inner Jacket
Inner Jacket Material:
Nom Wall (in.) Nom. Dia. (in.)
PVC - Polyvinyl Chloride 0.030
0.380
Outer Shield
Outer Shield Material:
Outer Shield Material Coverage (%)
TC - Tinned Copper
85.000
Outer Shield Separator Material:
Tissue Tape, 25% Overlap, Min.
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.035
Overall Cable
Overall Nominal Diameter:
0.484 in.
Mechanical Characteristics (Overall)
Storage Temperature Range:
-40°C To +90°C
Installation Temperature Range:
Flexing: -5°C To +90°C
Operating Temperature Range:
Bulk Cable Weight:
335 lbs/1000 ft.
Max. Recommended Pulling Tension:
157 lbs.
Min. Bend Radius/Minor Axis:
2.400 in.
Min. Bend/Installation:
2.400 in.
Min. Bend Radius (Continuous Flexing):
2.400 in.
Flex Cycle Rating:
1 Million Flexes
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
THHN/THWN Singles
Page 1 of 2
10-02-2017
THHN/THWN Singles
AWM Specification:
UL Style 2587 (600 V 90°C)
CSA Specification:
600 V AWM I/II A/B
EU Directive 2011/65/EU (ROHS II):
Yes
Other Specification:
AWM/STYLE 2587, AWM I/II A/B, FT1, VDE 0472, Section 803 Oil Test, EU Low Voltage Directive
2014/35/EC, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California
Proposition 65
Flame Test
CSA Flame Test:
FT1
Electrical Characteristics (Overall)
Nom. Inductance:
Inductance (µH/ft)
0.180
Nom. Capacitance Cond. to Other Cond. & Ground:
Description
Freq. (kHz) Capacitance (pF/ft)
Nom. Cond. to Cond 1.000
51.000
Nom. Ground.
92.000
1.000
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
4.100
Nominal Outer Shield DC Resistance:
1.490
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
73607WS 008100
100 FT
39.000 LB
GRAY
16AWG 26/30 7C SHIELDED
73607WS 0081000
1,000 FT
349.000 LB
GRAY
73607WS 008500
500 FT
181.500 LB
GRAY
73607WS 0085000
5,000 FT
345.000 LB
GRAY
Revision Number: 0
Notes
Item Desc
Revision Date: 09-27-2017
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Page 2 of 2
10-02-2017
很抱歉,暂时无法提供与“73607WS 0081000”相匹配的价格&库存,您可以联系我们找货
