Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
73804WS Multi-Conductor - 600V Shielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles
For more Information
please call
1-800-Belden1
General Description:
18 AWG stranded (16x30) bare copper conductors, PVC insulation, oil-resistant PVC inner jacket, tinned
copper braid shield, 85% coverage, oil-resistant overall PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material Dia. (in.)
3
18
16x30
BC - Bare Copper
0.047
Total Number of Conductors:
4
Ground Wire
Ground Wire (Y/N):
Y
Ground Wire AWG:
18
Ground Wire Stranding:
16X30
Ground Wire Conductor Material:
BC - Bare Copper
Ground Wire Insulation Material:
PVC - Polyvinyl Chloride
Insulation
Insulation Material
Wall Thickness (in.) Dia. (in.)
PVC - Polyvinyl Chloride 0.022
0.091
Insulation Color Code Chart:
Color
Description
Black
Individually Numbered
Yellow/Green Ground
Inner Jacket
Inner Jacket Material:
Nom Wall (in.) Nom. Dia. (in.)
PVC - Polyvinyl Chloride 0.030
0.286
Outer Shield
Outer Shield Material:
Outer Shield Material Coverage (%)
TC - Tinned Copper
85.000
Outer Shield Separator Material:
Tissue Tape, 25% Overlap, Min.
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.035
Overall Cable
Overall Nominal Diameter:
0.384 in.
Mechanical Characteristics (Overall)
Storage Temperature Range:
-40°C To +90°C
Installation Temperature Range:
Flexing: -5°C To +90°C
Operating Temperature Range:
Bulk Cable Weight:
184 lbs/1000 ft.
Max. Recommended Pulling Tension:
59 lbs.
Min. Bend Radius/Minor Axis:
1.920 in.
Min. Bend/Installation:
1.920 in.
Min. Bend Radius (Continuous Flexing):
1.920 in.
Flex Cycle Rating:
1 Million Flexes
Page 1 of 2
10-02-2017
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
THHN/THWN Singles
AWM Specification:
UL Style 2587 (600 V 90°C)
CSA Specification:
600 V AWM I/II A/B
EU Directive 2011/65/EU (ROHS II):
Yes
Other Specification:
AWM/STYLE 2587, AWM I/II A/B, FT1, VDE 0472, Section 803 Oil Test, EU Low Voltage Directive
2014/35/EC, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California
Proposition 65
Flame Test
CSA Flame Test:
FT1
Electrical Characteristics (Overall)
Nom. Inductance:
Inductance (µH/ft)
0.190
Nom. Capacitance Cond. to Other Cond. & Ground:
Description
Freq. (kHz) Capacitance (pF/ft)
Nom. Cond. to Cond 1.000
44.000
Nom. Ground.
79.000
1.000
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
6.600
Nominal Outer Shield DC Resistance:
2.260
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
73804WS 008100
100 FT
21.900 LB
GRAY
18AWG 19/30 4C SHIELDED
73804WS 0081000
1,000 FT
189.000 LB
GRAY
Revision Number: 0
Notes
Item Desc
Revision Date: 09-27-2017
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Page 2 of 2
10-02-2017
很抱歉,暂时无法提供与“73804WS 008100”相匹配的价格&库存,您可以联系我们找货
