74002E.01305
74002E.01305
    BELDEN
    BELDEN - 74002E.01305 - Networking Cable, DataTuff® Industrial Ethernet, 4 Pair, Screened, Cat5e, 26...
74002E.01305 数据手册
Part Number: 74002E DataTuff® Industrial Ethernet Cat 5e Moderate Flexing Cable Product Description DataTuff Industrial ETHERNET, CAT 5E 4P, 1 Gb/s, AWG 26(7), Stranded, Foil + 80% Braid, PVC Jacket, UL AWM 2464 Technical Specifications Product Overview Environmental Space: Indoor - Euroclass Eca Physical Characteristics (Overall) Conductor AWG Stranding 26 Stranded Material Construction n x D No. of Pairs BC - Bare Copper 7x0.16 mm 4 Conductor Count: 8 Total Number of Pairs: 4 Conductor Size: 26 AWG Insulation Material Nominal Diameter Diameter +/- Tolerance PP - Polypropylene 0.98 mm 0.05 mm Color Chart Number Color Pair 1 White/Blue & Blue Pair 2 White/Orange & Orange Pair 3 White/Green & Green Pair 4 White/Brown & Brown Outer Shield Material Type Material Min. Coverage [%] Tape Aluminum/Polyester Braid TC - Tinned Copper 80 % Note: Aluminum outside Outer Jacket Material Material Color Nominal Diameter Diameter +/- Tolerance PVC (Oil resistant) Black 6.5 mm 0.3 mm Construction and Dimensions Min Elongation at Breakof Conductors: 10 % Min Elongation at Breakof Insulation: 100 % Cabling Description 4 pairs twisted to cable core covered with a polyester foil Min Elongation at Breakof Jacket: 100 % Min Tensile Strength of Jacket: 15 MPa Electrical Characteristics Conductor DCR Max. Conductor DCR Max. DCR Unbalanced Within Pair [%] 145 Ohm/km 2 Ohm Capacitance Max. Capacitance Unbalance Max. Mutual Capacitance 1.6 pF/m 56 pF/m Shielding: SF/UTP - Overall Braid + Foil Impedance Nominal Characteristic Impedance Nominal Characteristic Tolerance Nominal Input Impedance 100 Ohm 5 Ohm 100 +/- 15 Ohm Delay Max. Delay Skew Nominal Velocity of Propagation (VP) [%] 40 ns/100m 60 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) Min. NEXT [dB] Min. PSNEXT [dB] Min. ACRF (ELFEXT) [dB] Min. PSACRF (PSELFEXT) [dB] Min. RL (Return Loss) [dB] 0.772 MHz 67 dB 64 dB 1 MHz 3.2 dB/100m 65.3 dB 62.3 dB 63.8 dB 60.8 dB 19.4 dB 20 dB 4 MHz 6 dB/100m 56.3 dB 53.3 dB 51.8 dB 48.8 dB 23 dB 10 MHz 9.5 dB/100m 50.3 dB 47.3 dB 43.8 dB 40.8 dB 25 dB 16 MHz 12.1 dB/100m 47.2 dB 44.2 dB 39.7 dB 36.7 dB 25 dB 20 MHz 13.6 dB/100m 45.8 dB 42.8 dB 37.8 dB 34.8 dB 25 dB 25 MHz 15.3 dB/100m 44.3 dB 41.3 dB 35.8 dB 32.8 dB 24.3 dB 31.25 MHz 17.1 dB/100m 42.9 dB 39.9 dB 33.9 dB 40.9 dB 23.6 dB 62.5 MHz 24.8 dB/100m 38.3 dB 35.4 dB 27.9 dB 24.9 dB 21.5 dB 100 MHz 32 dB/100m 35.3 dB 32.3 dB 23.8 dB 20.8 dB 20.1 dB Current Element Max. Recommended Current [A] Conductor 1 A Voltage Voltage Rating [V] 450 V DC and 300 V AC Temperature Range Installation Temp Range: -15°C To +60°C Storage Temp Range: -40°C To +80°C Operating Temp Range: -40°C To +80°C Mechanical Characteristics Oil Resistance: IEC 60811-2-1 Max Recommended Pulling Tension: 80 N Min Bend Radius (W/o Pulling Strength): 70 mm Min Setting Radius: 35 mm Standards ISO/IEC Compliance: ISO/IEC 11801 Ed. 2.2:2002/A2:2010/C1:2011 and ISO/IEC 24702 CPR Euroclass: Eca CENELEC Compliance: EN 50173-1 Ed. 3:2011 Data Category: Category 5e ANSI Compliance: ANSI/TIA/EIA 568-B.2-1 (2002) Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2016-01-12 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1-2 Part Number Variants Item # Color 74002E.01305 Black 74002E.01500 Black Patent: https://www.belden.com/resources/patents History Revision Number: 3 © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
74002E.01305
物料型号:74002E 器件简介: - 产品名称:DataTuff® Industrial Ethernet Cat 5e Moderate Flexing Cable - 产品描述:DataTuff Industrial Ethernet, CAT 5E 4P, 1 Gb/s, AWG 26(7), Stranded, Foil + 80% Braid, PVC Jacket, UL AWM 2464 Technical Specifications 引脚分配: - 导体:26AWG,7x0.16mm - 绝缘材料:PP-Polypropylene,直径98mm,公差0.05mm - 对颜色:1对白/蓝&蓝,2对白/橙&橙,3对白/绿&绿,4对白/棕&棕 参数特性: - 导体直流电阻:最大145欧姆/公里 - 电容不平衡:最大1.6pF/m - 互电容:最大56pF/m - 特性阻抗:100欧姆,公差5欧姆 - 输入阻抗:100+-15欧姆 - 延迟偏差:最大40ns/100m - 传播速度:60% - 高频参数(不同频率下的插入损耗和NEXT等):详细数据请参考文档 功能详解: - 适用于工业以太网 - 以太网类别:5e - 温度范围:安装-15°C至+60°C,存储-40°C至+80°C,工作-40°C至+80°C - 机械特性:推荐拉力80N,弯曲半径70mm(无拉力强度),设置半径35mm 应用信息: - 符合ISO/IEC 11801 Ed.2 2:2002/A22010/C1:2011和ISO/EC 24702标准 - 欧标:Eca - NELEC:EN50173-1 Ed.3:2011 - SI:ANSI/TIAEIA 568-8.2-1(2002) 封装信息: - 外屏蔽材料:铝/聚酯带,最小覆盖率未提供 - 编织:TC-镀锡铜,80% - 外护套材料:耐油PVC,黑色,直径6.5mm,公差±0.3mm
74002E.01305 价格&库存
很抱歉,暂时无法提供与“74002E.01305”相匹配的价格&库存,您可以联系我们找货
