7950A 337500
7950A 337500
    BELDEN
    COMPOSITE CABLE PVC
7950A 337500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7950A Composite - Composite Data, Audio, Video, Security and Control Cable For more Information please call 1-800-Belden1 General Description: Siamese Composite - (1)Cat 5 4-pair, 24 AWG unshielded plus (4)16 AWG stranded (65x34) bare copper conductors, polyolefin insulation on the pairs; PVC insulation on the conductors, overall F-R PVC jacket. Jacket sequentially marked. Twisted Pair Physical Characteristics Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (mm) 4 24 Solid BC - Bare Copper 0.508 Insulation Insulation Material: Insulation Material Dia. (mm) PO - Polyolefin 0.914 Twisted Pair Color Code Chart: Number Color 1 White/Blue Stripe and Blue 2 White/Orange Stripe and Orange 3 White/Green Stripe and Green 4 White/Brown Stripe and Brown Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (mm) 4.953 Outer Jacket Ripcord: Yes Outer Jacket Color Code Chart: Color Blue Electrical Characteristics Premise Cable Electricals: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. SRL (dB) Fitted Imp. (Ohms) 1.0 2.000 62 N/A 23 100 ± 15% 4.0 4.100 53 N/A 23 100 ± 15% 8.0 5.800 48 N/A 23 100 ± 15% 10.0 6.500 47 N/A 23 100 ± 15% 16.0 8.200 44 N/A 23 100 ± 15% 20.0 9.300 42 N/A 23 100 ± 15% 25.0 10.400 41 N/A 22 100 ± 15% 31.25 11.700 39 N/A 21 100 ± 15% 62.5 17.000 35 N/A 18 100 ± 15% 100 22.000 32 N/A 16 100 ± 15% Page 1 of 4 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7950A Composite - Composite Data, Audio, Video, Security and Control Cable Multi Conductor Physical Characteristics Conductor AWG: # Conductors AWG Stranding Conductor Material Dia. (mm) 4 16 65x34 BC - Bare Copper 1.499 Insulation Insulation Material: Insulation Material Dia. (mm) PVC - Polyvinyl Chloride 2.007 Insulation Color Code Chart: Number Color 1 Red 2 White 3 Green 4 Black Electrical Characteristics Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 49.215 Nominal Velocity of Propagation: VP (%) 70.000 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 30.776 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 5 Amps per conductor @ 25°C Other Electrical Characteristic 1: Third party verified to TIA/EIA-568-B.2, Category 5 Physical Characteristics (Overall) Conductor Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 9.906 mm Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 130.962 Kg/Km Page 2 of 4 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7950A Composite - Composite Data, Audio, Video, Security and Control Cable Max. Recommended Pulling Tension: 711.712 N Min. Bend Radius/Minor Axis: 101.600 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: NEMA WC-63.1, Category 5 Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Max. Operating Voltage - UL: Voltage 300 V RMS Notes (Overall) Notes: Overall jacket sequentially marked. Put Ups and Colors: Item # Revision Number: 0 Putup Ship Weight Color Notes Item Desc Revision Date: 08-05-2013 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 4 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7950A Composite - Composite Data, Audio, Video, Security and Control Cable Page 4 of 4 10-30-2013
7950A 337500 价格&库存
很抱歉,暂时无法提供与“7950A 337500”相匹配的价格&库存,您可以联系我们找货
