8132FO 060500
8132FO 060500
    BELDEN
    CBL 2PR 28AWG SHLD
8132FO 060500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8132FO Multi-Conductor - Low Capacitance Computer Cable for EIA RS-232/485 For more Information please call 1-800-Belden1 General Description: 28 AWG stranded (7x36) TC conductors, Datalene® insulation, twisted pairs, overall Beldfoil shield (100% coverage), 28 AWG stranded TC drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 28 7x36 TC - Tinned Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® Wall Thickness (mm) FPE - Foam Polyethylene 0.381 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® (Z-Fold®) Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 28 7x36 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.889 Overall Cable Overall Nominal Diameter: 5.461 mm Pair Pair Color Code Chart: Number Color 1 White/Blue & Blue/White 2 White/Orange & Orange White Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +80°C Non-UL Temperature Rating: 80°C (UL AWM Style 2919) Bulk Cable Weight: 25.299 Kg/Km Min. Bend Radius/Minor Axis: 57.150 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2 AWM Specification: UL Style 2919 (30 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes Page 1 of 2 09-11-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8132FO Multi-Conductor - Low Capacitance Computer Cable for EIA RS-232/485 EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 120 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 36.091 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 65.62 Nominal Velocity of Propagation: VP (%) 78 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 213.265 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 75.7911 Max. Operating Voltage - UL: Voltage Description 150 V RMS CL2 30 V RMS UL AWM Style 2919 Max. Recommended Current: Current 1 Amp per conductor @ 25°C Notes (Overall) Notes: Datalene® insulation features include low dielectric constant and a dissipation factor for high-speed, low distortion data handling. Physical properties include good crush resistance and light weight. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 8132FO 0601000 1,000 FT 20.000 LB CHROME C 2 PR #28 FHDPE SH PVC 8132FO 060500 500 FT 10.000 LB CHROME C 2 PR #28 FHDPE SH PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 11-13-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 09-11-2017
8132FO 060500 价格&库存
很抱歉,暂时无法提供与“8132FO 060500”相匹配的价格&库存,您可以联系我们找货
