Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
8135 Multi-Conductor - Low Capacitance Computer Cable for EIA RS-232/485
For more Information
please call
1-800-Belden1
Description:
28 AWG stranded (7x36) TC conductors, Datalene® insulation, overall Beldfoil® (100% coverage) + TC
braid shield (65% coverage), 28 AWG stranded TC drain wire, PVC jacket
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material
5
28
7x36
TC - Tinned Copper
Insulation
Insulation Material:
Insulation Trade Name Insulation Material
Datalene®
FPE - Foam Polyethylene
Outer Shield
Outer Shield Material:
Layer # Outer Shield Trade Name Type Outer Shield Material
1
Beldfoil®
2
Coverage (%)
Tape Aluminum Foil-Polyester Tape w/Shorting Fold 100
Braid TC - Tinned Copper
65
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
28
7x36
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Overall Cabling
Overall Nominal Diameter:
0.288 in.
Pair
Pair Color Code Chart:
Number Color
1
White/Blue & Blue/White
2
White/Orange & Orange/White
3
White/Green & Green/White
4
White/Brown & Brown/White
5
White/Gray & Gray/White
Pair Lay Length & Direction:
Lay Length (in.) Twists/ft. (twist/ft)
0.830
14.400
Mechanical Characteristics (Overall)
Operating Temperature Range:
-30°C To +80°C
UL Temperature Rating:
80°C (UL AWM Style 2919)
Bulk Cable Weight:
43 lbs/1000 ft.
Min. Bend Radius (Install)/Minor Axis:
2 in.
Page 1 of 3
06-23-2009
2 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CL2
AWM Specification:
UL Style 2919 (30 V 80°C)
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
UL1685 UL Loading
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
120
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
11
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
Nominal Velocity of Propagation:
VP (%)
78
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
65
Nominal Outer Shield DC Resistance:
4.2
Max. Operating Voltage - UL:
Voltage
30 V RMS (UL AWM Style 2919); 150 V RMS
Max. Recommended Current:
Current
0.9 Amps per conductor @ 25°C
Notes (Overall)
Notes: Datalene® insulation features include low dielectric constant and a dissipation factor for high-speed, low-distortion data
handling. Physical properties include good crush resistance and light weight.
Put Ups and Colors:
Page 2 of 3
06-23-2009
Item #
Putup
Ship Weight
Color
8135 060100
100 FT
4.300 LB
CHROME
8135 0601000
1,000 FT
40.000 LB
CHROME
Notes
Item Desc
5 PR #28 FHDPE SH PVC
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 2
Revision Date: 05-13-2008
© 2008 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications
described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not
ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express,
statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or
exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the
compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and
the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide
for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not
to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
Page 3 of 3
06-23-2009
很抱歉,暂时无法提供与“8135 0601000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+71.816841000+9.33596
