8232 0102000
8232 0102000
    BELDEN
    RG-59/U TYPE TRIAX
8232 0102000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8232 Coax - RG-59/U Type For more Information please call 1-800-Belden1 General Description: 20 AWG solid .032" bare copper conductor, gas-injected foam HDPE insulation, bare copper braid shields (95% and 80% coverage), polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (mm) 1 20 Solid BC - Bare Copper 0.8128 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (mm) Gas-injected FHDPE - Foam High Density Polyethylene 3.683 Inner Shield Inner Shield Material: Type Inner Shield Material Coverage (%) Braid BC - Bare Copper 95 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (mm) PE - Polyethylene 5.715 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 80 Outer Jacket Outer Jacket Material: Outer Jacket Material PE - Polyethylene Overall Cable Overall Nominal Diameter: 8.001 mm Mechanical Characteristics (Overall) Operating Temperature Range: -55°C To +80°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 81.851 Kg/Km Max. Recommended Pulling Tension: 556.025 N Min. Bend Radius/Minor Axis: 82.550 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 01-09-2015 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8232 Coax - RG-59/U Type CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Aerial: Yes - when supported by a messenger wire Suitability - Burial: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 88232 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/m) 0.318257 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 53.1522 Nominal Velocity of Propagation: VP (%) 83 Nominal Delay: Delay (ns/m) 4.00282 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 32.81 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/km) 8.2025 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 9.1868 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 0.9843 3.6 1.9686 10 2.9529 71.5 6.8901 135 9.843 270 13.7802 360 15.7488 540 19.3579 720 22.967 750 23.2951 1000 27.2323 1500 34.4505 2250 43.9654 3000 52.1679 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Minimum Structural Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 850 21 851 3000 15 Page 2 of 3 01-09-2015 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8232 Coax - RG-59/U Type Sweep Test Sweep Testing: 100% sweep tested 5 MHz to 3 GHz. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 8232 0101000 1,000 FT 60.000 LB BLACK C RG-59/U TYPE TRIAX 8232 0102000 2,000 FT 118.000 LB BLACK C RG-59/U TYPE TRIAX 8232 010500 500 FT 31.000 LB BLACK RG-59/U TYPE TRIAX Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 07-03-2012 © 2015 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-09-2015
8232 0102000 价格&库存
很抱歉,暂时无法提供与“8232 0102000”相匹配的价格&库存,您可以联系我们找货
  • 2000+23.635362000+3.03149
