8268 0101000
8268 0101000
    BELDEN
    #13 PE DBLB PVC
8268 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8268 Coax - 50 Ohm Coax For more Information please call 1-800-Belden1 General Description: 13 AWG stranded (7x21) .089" silver-plated copper conductor, polyethylene insulation, double silver-plated copper braid shield (95% coverage), non-contaminating PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 13 7x21 Dia. (in.) SPC - Silver Plated Copper .089 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) PE - Polyethylene .285 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Braid SPC - Silver Plated Copper 95.000 2 Braid SPC - Silver Plated Copper 95.000 Outer Jacket Outer Jacket Material: Outer Jacket Material PVCNC - Polyvinyl Chloride Non-Contaminating Overall Cable Overall Nominal Diameter: 0.425 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 60°C Bulk Cable Weight: 131 lbs/1000 ft. Max. Recommended Pulling Tension: 225 lbs. Min. Bend Radius/Minor Axis: 6 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMX CEC/C(UL) Specification: CMX AWM Specification: UL Style 1354 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-C-17, M17/075 Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8268 Coax - 50 Ohm Coax RG Type: 214/U Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) .077 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 30.8 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.54 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.7 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 0.7 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .17 10 .55 50 1.3 100 1.9 200 2.7 400 4.1 700 6.5 900 7.6 1000 8.0 4000 20.0 Max. Power Rating: Freq. (MHz) Rating (W) 50 1500 100 907 200 549 400 332 700 221 900 184 1000 171 4000 62 Max. Operating Voltage - UL: Voltage Description 30 V RMS UL AWM Style 1354 300 V RMS NEC Max. Operating Voltage - Non-UL: Voltage 3700 V RMS (MIL-Spec.) Notes (Overall) Notes: Non-SWR swept version of RG-214. Put Ups and Colors: Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8268 Coax - 50 Ohm Coax Item # Putup Ship Weight Color Notes Item Desc 8268 0101000 1,000 FT 140.000 LB BLACK C M17/164-00001 COAX 8268 010500 500 FT 70.500 LB BLACK C M17/164-00001 COAX Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 07-29-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
8268 0101000 价格&库存
很抱歉,暂时无法提供与“8268 0101000”相匹配的价格&库存,您可以联系我们找货
  • 1000+218.836951000+28.27203
