8268 010500
8268 010500
    BELDEN
    #13 PE DBLB PVC
8268 010500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8268 Coax - 50 Ohm Coax For more Information please call 1-800-Belden1 Description: 13 AWG stranded (7x21) .089" silver-plated copper conductor, polyethylene insulation, double silver-plated copper braid shield (97% coverage), non-contaminating PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 13 7x21 Dia. (mm) SPC - Silver Plated Copper 2.2606 Insulation Insulation Material: Insulation Material Dia. (mm) PE - Polyethylene 7.239 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Braid SPC - Silver Plated Copper 95 2 Braid SPC - Silver Plated Copper 97 Outer Jacket Outer Jacket Material: Outer Jacket Material PVCNC - Polyvinyl Chloride Non-Contaminating Overall Cabling Overall Nominal Diameter: 10.795 mm Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 60°C (UL AWM Style 1354) Bulk Cable Weight: 190.490 Kg/Km Max. Recommended Pulling Tension: 1000.850 N Min. Bend Radius (Install)/Minor Axis: 152.400 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMX CEC/C(UL) Specification: CMX AWM Specification: UL Style 1354 (30 V 60°C) EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 Page 1 of 3 06-03-2011 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8268 Coax - 50 Ohm Coax EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-DTL-17, M17/164-00001 RG Type: 214/U Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/m) 0.252637 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 101.055 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/m) 5.05274 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 5.5777 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 2.2967 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 0.55777 10 1.80455 50 4.2653 100 6.2339 200 8.8587 400 13.4521 700 21.3265 900 24.9356 1000 26.248 4000 65.62 Max. Power Rating: Freq. (MHz) Rating (W) 50 1500 100 907 200 549 400 332 700 221 900 184 Page 2 of 3 06-03-2011 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8268 Coax - 50 Ohm Coax 1000 171 4000 62 Max. Operating Voltage - UL: Voltage Description 30 V RMS UL AWM Style 1354 300 V RMS NEC Max. Operating Voltage - Non-UL: Voltage 3700 V RMS (MIL-Spec.) Notes (Overall) Notes: Non-SWR swept version of RG-214. Related Documents: No related documents are available for this product Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 8268 0101000 305 MT 63.503 KG BLACK C M17/164-00001 COAX (10DAY) 8268 010500 152 MT 31.978 KG BLACK C M17/164-00001 COAX (10DAY) Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 05-19-2011 © 2011 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 06-03-2011
8268 010500 价格&库存
很抱歉,暂时无法提供与“8268 010500”相匹配的价格&库存,您可以联系我们找货
  • 500+219.36462500+28.39447
