Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
8279 Coax - Miniature
For more Information
please call
1-800-Belden1
General Description:
23 AWG stranded (7x32) .023" bare compacted copper conductor, polyethylene insulation, tinned copper
braid shield (95% coverage), polyethylene jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
23
7x32
Dia. (in.)
BCC - Bare Compacted Copper .023
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material Dia. (in.)
PE - Polyethylene
.146
Outer Shield
Outer Shield Material:
Type Outer Shield Material Coverage (%)
Braid TC - Tinned Copper
95
Outer Jacket
Outer Jacket Material:
PE - Polyethylene
Overall Cable
Overall Nominal Diameter:
0.220 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-55°C To +80°C
Non-UL Temperature Rating:
80°C
Bulk Cable Weight:
26 lbs/1000 ft.
Max. Recommended Pulling Tension:
45 lbs.
Min. Bend Radius/Minor Axis:
2.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
Mini 59/U
Suitability
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes
Suitability - Aerial:
Yes - When supported by a messenger wire
Page 1 of 3
01-05-2017
Suitability - Burial:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
75
Nom. Inductance:
Inductance (µH/ft)
.118
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
21.0
Nominal Velocity of Propagation:
VP (%)
66
Nominal Delay:
Delay (ns/ft)
1.54
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
19.1
Nominal Outer Shield DC Resistance:
4.5
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1
.4
3.6
.6
10.0
1.2
71.5
3.3
135
4.7
270
6.8
360
8.0
540
9.9
720
11.6
750
11.9
1000
13.8
Max. Operating Voltage - Non-UL:
Voltage
2300 V RMS
Other Electrical Characteristic 1:
Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge
and termination.
Other Electrical Characteristic 2:
Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, using a 75 Ohm fixed bridge and
termination.
Minimum Return Loss:
Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB)
5.000
216.000
27.000
216.000
850.000
21.000
Sweep Test
Sweep Testing:
100% Sweep tested 5MHz to 850MHz.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
8279 0101000
1,000 FT
23.000 LB
BLACK
C
MINI VIDEO CABLE
8279 010500
500 FT
11.500 LB
BLACK
MINI VIDEO CABLE
Notes:
C = CRATE REEL PUT-UP.
Page 2 of 3
01-05-2017
Revision Number: 3
Revision Date: 09-30-2009
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“8279 0101000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+15.521011000+1.94133
