8305 060500
8305 060500
    BELDEN
    CBL 5PR 22AWG SHLD
8305 060500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8305 Multi-Conductor - Low Capacitance Computer Cable for EIA RS-232 Applications For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) tinned copper conductors, semi-rigid PVC insulation, twisted pairs, overall Beldfoil® (100% coverage) + tinned copper braid shield (65% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 5 22 7x30 TC - Tinned Copper Total Number of Conductors: 10 Insulation Insulation Material: Insulation Material Wall Thickness (in.) S-R PVC - Semi-Rigid Polyvinyl Chloride 0.011 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 2 Braid TC - Tinned Copper 65 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.035 Overall Cable Overall Nominal Diameter: 0.322 in. Pair Pair Color Code Chart: Number Color 1 Black & Red 2 Black & White 3 Black & Green 4 Black & Blue 5 Black & Yellow Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 2464) Bulk Cable Weight: 63 lbs/1000 ft. Min. Bend Radius/Minor Axis: 3.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG AWM Specification: UL Style 2464 (300 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8305 Multi-Conductor - Low Capacitance Computer Cable for EIA RS-232 Applications EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 35 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 63 Nominal Velocity of Propagation: VP (%) 60 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.8 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.1 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color 8305 060100 100 FT 7.200 LB CHROME Notes Item Desc 8305 0601000 1,000 FT 67.000 LB CHROME C 5 #22 PR PVC SHLD PVC 8305 060500 500 FT 35.000 LB CHROME C 5 #22 PR PVC SHLD PVC 8305 0605000 5,000 FT 340.000 LB CHROME 5 #22 PR PVC SHLD PVC 5 #22 PR PVC SHLD PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-22-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 01-05-2017
8305 060500
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电晶体管开关,具有高输入阻抗和低输出阻抗,适用于高速光耦应用。
3. 引脚分配:EL817有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:主要参数包括工作温度范围-40~85℃,输入电流1mA,输出电流50mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用6引脚DIP封装。
8305 060500 价格&库存
很抱歉,暂时无法提供与“8305 060500”相匹配的价格&库存,您可以联系我们找货
  • 1+149.107661+19.37950
  • 50+116.9386750+15.19850
  • 100+105.20133100+13.67300
  • 152+92.76844152+12.05710
