Part Number: 83659
Audio/Control/Instrumentation, (9) 18 AWG (19x30) TC, FEP/FEP, Foil+TC
Braid Shld, CMP
Product Description
Nine 18 AWG stranded (19x30) tinned copper conductors, plenum, Teflon® (FEP) insulation, overall Beldfoil® shield (100% coverage) plus tinned copper braid
shield (85% coverage), Teflon® (FEP) jacket.
Technical Specifications
Physical Characteristics (Overall)
Conductor
AWG Stranding
18
19x30
Material
No. of Conductors
TC - Tinned Copper 9
Conductor Count:
9
AWG Size:
18
Insulation
Material
Nominal Wall Thickness
FEP - Fluorinated Ethylene Propylene 0.0065 in
Color Chart
Number
Color
1
Black
2
White
3
Red
4
Green
5
Orange
6
Blue
7
White/Black
8
Red/Black
9
Green/Black
Outer Shield Material
Type Layer
Material
Material Trade Name Coverage [%]
Tape 1
Aluminum Foil-Polyester Tape Beldfoil®
100 %
Braid 2
TC - Tinned Copper
85 %
Outer Jacket Material
Material
Nominal Diameter Nominal Wall Thickness
FEP - Fluorinated Ethylene Propylene 0.265 in
0.015 in
Electrical Characteristics
Conductor DCR
Nominal Conductor DCR Nominal Outer Shield DCR
5.8 Ohm/1000ft
2.7 Ohm/1000ft
Capacitance
Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield
33 pF/ft
Inductance
60 pF/ft
Nominal Inductance
0.14 µH/ft
Current
Element
Max. Recommended Current [A]
10C Temperature Rise 3.8 Amps per conductor @ 25°C ambient
Voltage
UL Voltage Rating
300V RMS
Temperature Range
Operating Temp Range:
-70°C To +200°C
Mechanical Characteristics
Bulk Cable Weight:
81 lbs/1000ft
Max Recommended Pulling Tension:
216 lbs
Min Bend Radius/Minor Axis:
2.75 in
Standards
NEC Articles:
800
NEC/(UL) Specification:
CMP
CEC/C(UL) Specification:
CMP
CPR Euroclass:
Eca
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2003/96/EC (BFR):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive 2015/863/EU:
Yes
EU Directive Compliance:
EU Directive 2003/11/EC (BFR)
EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Suitability
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes
Flammability, LS0H, Toxicity Testing
UL Flammability:
NFPA 262
CSA Flammability:
FT6
Part Number
Plenum (Y/N):
Yes
Variants
Item #
83659 002100
Color Footnote
RED
83659 0021000 RED
C
83659 002500
C
RED
83659 0025000 RED
CZ
Footnote:
C - CRATE REEL PUT-UP.
Footnote:
Z - FINAL PUT-UP MAY VARY (= OR -) 10% FOR SPOOLS OR REELS AND (+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN.
© 2018 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's
inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product
itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
很抱歉,暂时无法提供与“83659 002100”相匹配的价格&库存,您可以联系我们找货
