Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
84316 Coax - 50 Ohm Coax
For more Information
please call
1-800-Belden1
General Description:
26 AWG stranded (7x34) .020" silver-plated copper-covered steel conductor, TFE Teflon® insulation,
silver-plated copper braid shield (95% coverage), FEP jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
26
7x34
Dia. (in.)
SPCCS - Silver Plated Copper Covered Steel .020
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Trade Name Insulation Material
Teflon®
Dia. (in.)
TFE - Tetrafluoroethylene .058
Outer Shield
Outer Shield Material:
Type Outer Shield Material
Coverage (%)
Braid SPC - Silver Plated Copper 95
Outer Jacket
Outer Jacket Material:
FEP - Fluorinated Ethylene Propylene
Overall Cable
Overall Nominal Diameter:
0.096 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-70°C To +200°C
Non-UL Temperature Rating:
200°C
Bulk Cable Weight:
10 lbs/1000 ft.
Max. Recommended Pulling Tension:
21 lbs.
Min. Bend Radius/Minor Axis:
1 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Military Specification:
MIL-C-17, M17/113-RG316
RG Type:
316/U
Plenum/Non-Plenum
Plenum (Y/N):
No
Page 1 of 3
01-05-2017
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
0.067
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
29.0
Nominal Velocity of Propagation:
VP (%)
69.5
Nominal Delay:
Delay (ns/ft)
1.48
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
84.1
Nominal Outer Shield DC Resistance:
6.5
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1.000
1.200
10.000
2.700
50.000
5.600
100.000
8.300
200.000
12.000
400.000
17.500
700.000
23.700
900.000
27.300
1000.000
29.000
1500.000
36.500
2000.000
42.500
2400.000
47.200
3000.000
53.600
Max. Operating Voltage - Other:
Voltage
Description
Military Specification 900 V RMS
Minimum Structural Return Loss:
Freq. (MHz) Min. SRL (dB)
50.000
30.000
100.000
30.000
400.000
23.000
1000.000
21.000
3000.000
17.000
Notes (Overall)
Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
84316 001100
100 FT
1.100 LB
BROWN
E
M17/13-RG316 COAX
84316 0011000
1,000 FT
11.000 LB
BROWN
E
M17/13-RG316 COAX
84316 001500
500 FT
6.000 LB
BROWN
E
M17/13-RG316 COAX
Notes:
E = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25'
Page 2 of 3
01-05-2017
Revision Number: 5
Revision Date: 08-22-2012
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“84316 0011000”相匹配的价格&库存,您可以联系我们找货
