8720.00305
8720.00305
    BELDEN
    BELDEN - 8720.00305 - Multipair Cable, Screened, 1 Pair, 14 AWG, 305 ft, 93 m
8720.00305 数据手册
Part Number: 8720 Single-Pair, (1 pr) 14 AWG (19x27) TC, PE/PVC, Foil Shld Product Description One 14 AWG pair stranded (19x27) TC conductors, twisted pair, polyethylene insulation, overall Beldfoil® shield (100% coverage), PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 14 19x27 Material No. of Pairs TC - Tinned Copper 1 Conductor Count: 2 Total Number of Pairs: 1 Conductor Size: 14 AWG Insulation Material Nominal Wall Thickness PE - Polyethylene 0.032 in Color Chart Number 1 Color Black & Clear Outer Shield Material Type Material Trade Name Material Coverage [%] Drainwire Material Tape Aluminum/Polyester Beldfoil® (Z-Fold®) 100 % Drainwire AWG Drainwire Construction n x D TC - Tinned Copper 16 Stranded mm Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.355 in 0.035 in Electrical Characteristics Conductor DCR Nominal Conductor DCR 2.9 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield 24 pF/ft Shielding: Inductance Nominal Inductance 0.2 µH/ft Impedance Nominal Characteristic Impedance 58 Ohm 47 pF/ft Foil(s) or Copper Tape(s) Current Max. Recommended Current [A] 9.5 Amps per conductor @ 25°C Voltage Non-UL Voltage Rating 300 V RMS UL Description UL Voltage Rating UL AWM Style 20253 600 V RMS CSA 300 V RMS Temperature Range UL Temp Rating: 80°C (UL AWM Style 20253) Operating Temp Range: -20°C To +80°C Mechanical Characteristics Bulk Cable Weight: 64 lbs/1000ft Max Recommended Pulling Tension: 160 lbs Min Bend Radius/Minor Axis: 3.75 in Standards NEC Articles: 800 NEC/(UL) Specification: CL2 CEC/C(UL) Specification: AWM II A UL AWM Style: UL Style 20253 (600 V 80°C) CPR Euroclass: Eca Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1685 UL Loading CSA Flammability: FT1 UL voltage rating: 600 V RMS Plenum/Non-Plenum Plenum (Y/N): No Part Number Variants Item # 8720.00305 Color Footnote Chrome 8720 0601000 Chrome C 8720 0602000 Chrome C 8720 060500 Chrome C 8720 0605000 Chrome C 8720 060U500 Chrome Footnote: C - CRATE REEL PUT-UP. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
8720.00305 价格&库存
很抱歉,暂时无法提供与“8720.00305”相匹配的价格&库存,您可以联系我们找货
