8723 060U1000
8723 060U1000
    BELDEN
    MULTI-PAIR 4COND 22AWG CHRM 1000
8723 060U1000 数据手册
Part Number: 8723 Audio, Control & Instrument, #22-2pr, PO, Indiv. Foil, PVC Jkt, CM Product Description Audio, Control & Instrument Cable, 22 AWG stranded (7x30) tinned copper conductors, polypropylene insulation, twisted pairs, individually Beldfoil® shielded (100% coverage), 24 AWG stranded tinned copper drain wire, PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 22 7x30 Material No. of Pairs TC - Tinned Copper 2 Conductor Count: 4 Conductor Size: 22 AWG Insulation Material Nominal Wall Thickness PP - Polypropylene 0.009 in Color Chart Number Color 1 Red & Black 2 Green & White Inner Shield Material Type Material Material Trade Name Coverage [%] Drainwire Material Tape Aluminum Foil-Polyester Tape Beldfoil® (Z-Fold®-foil side out) 100 % Drainwire AWG Drainwire Construction n x D TC - Tinned Copper 24 Outer Shield Material Material Unshielded Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.16 in 0.02 in Electrical Characteristics Conductor DCR Individual Pair Nominal Shield DCR Nominal Conductor DCR 15 Ohm/1000ft 14.7 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield 33 pF/ft Inductance Nominal Inductance 0.17 µH/ft 62 pF/ft 7x32 Impedance Nominal Characteristic Impedance 52 Ohm High Frequency (Nominal/Typical) Nom. Insertion Loss 10 dB/100m Delay Nominal Velocity of Propagation (VP) [%] 66 % Current Max. Recommended Current [A] Per conductor @ 25°C (10C temperature rise): 2.3 A Voltage UL Voltage Rating 300 V RMS Temperature Range UL Temp Rating: 60°C Operating Temp Range: -20°C To +75°C Mechanical Characteristics Bulk Cable Weight: 17 lbs/1000ft Max Recommended Pulling Tension: 42 lbs Min Bend Radius/Minor Axis: 1.75 in Standards NEC Articles: 800 NEC/(UL) Specification: CM CEC/C(UL) Specification: CM CPR Euroclass: Eca Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Suitability - Outdoor: No Flammability, LS0H, Toxicity Testing UL Flammability: UL1685 (UL Loading) ISO/IEC Flammability: IEC 60332-1-2 UL voltage rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 82723, 87723, 88723 Part Number Variants Item # Color Footnote 8723.001000 Chrome 8723.0030 Chrome 8723.00U152 Chrome 8723.00U305 Chrome 8723.01152 Chrome 8723.011524 Chrome 8723.013048 Chrome 8723.01305 Chrome 8723.013050 Chrome 8723.01610 Chrome 8723.02500 Chrome 8723 060100 Chrome 8723 0601000 Chrome C 8723 06010000 Chrome C Y 8723 06010001 Chrome C 8723 06015000 Chrome 8723 0601640 Chrome 8723 0602000 Chrome C 8723 0603280 Chrome C 8723 060500 Chrome 8723 0605000 Chrome C 8723 0609999 Chrome C Y 8723 060U1000 Chrome 8723 060U2000 Chrome 8723 060U500 Chrome Footnote: C - CRATE REEL PUT-UP. Footnote: Y - FINAL PUT-UP LENGTH MAY VAR -10% TO +20% FROM LENGTH SHOWN. MAY CONTAIN 2 PIECES. MINIMUM LENGTH OF ANY ONE PIECE IS 1500'. © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
8723 060U1000 价格&库存
很抱歉,暂时无法提供与“8723 060U1000”相匹配的价格&库存,您可以联系我们找货
8723 060U1000
  • 1+14003.647501+1754.35700
  • 2+12863.473702+1611.51760
库存:1
