8728 0601000
8728 0601000
    BELDEN
    2 #22 SHPR PP PVC 1=1000'
8728 0601000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8728 Multi-Conductor - Special Audio, Communication and Instrumentation Cable For more Information please call 1-800-Belden1 Description: 22 AWG stranded (7x30) TC conductors, polypropylene insulation, cabled in pairs, overall Beldfoil® shield (100% coverage), 24 AWG stranded TC drain wires, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (mm) 2 22 7x30 TC - Tinned Copper 0.762 Insulation Insulation Material: Insulation Material Wall Thickness (mm) Dia. (mm) PP - Polypropylene 0.254 1.27 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material Coverage (%) Layer 1 Beldfoil® Tape Aluminum Foil-Polyester Tape 100 Layer 2 Tape Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: Stranded Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 Stranded TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.7112 Overall Cabling Overall Nominal Diameter: 5.461 mm Pair Pair Color Code Chart: Number Color 1 Black & Red 2 White & Green Pair Lay Length & Direction: Lay Length (mm) Twists/ft. (twist/m) Page 1 of 3 05-10-2011 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8728 Multi-Conductor - Special Audio, Communication and Instrumentation Cable 31.749875 31.498 Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 2717) Bulk Cable Weight: 41.670 Kg/Km Max. Recommended Pulling Tension: 161.914 N Min. Bend Radius (Install)/Minor Axis: 31.750 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM NEC Articles: 800 CEC/C(UL) Specification: CM AWM Specification: UL Style 2717 (300 V 80°C) EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/m) 0.59058 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 114.835 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 203.422 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 55.777 Ind. Pair Nominal Shield DC Resistance @ 20 54.465 Ohm/km Page 2 of 3 05-10-2011 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8728 Multi-Conductor - Special Audio, Communication and Instrumentation Cable Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 54.465 Ohm/km Max. Operating Voltage - UL: Voltage 300 V RMS (UL AWM Style 2717) Max. Recommended Current: Current 2.3 Amps per conductor @ 25°C Notes (Overall) Notes: Each pair Beldfoil® shielded with individual drain wire plus a polyester film over each shield. Related Documents: No related documents are available for this product Put Ups and Colors: Item # Putup Ship Weight Color 8728 060U1000 305 MT 13.608 KG CHROME Notes Item Desc 8728 060U500 152 MT 7.031 KG CHROME 8728 0601000 305 MT 14.061 KG CHROME C 2 #22 SHPR PP PVC 8728 060500 152 MT 7.031 KG CHROME C 2#22 SHPR PP PVC 2 #22 SHPR PP PVC 2#22 SHPR PP PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 04-16-2008 © 2011 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 05-10-2011
8728 0601000 价格&库存
很抱歉,暂时无法提供与“8728 0601000”相匹配的价格&库存,您可以联系我们找货
