89120 0101000
89120 0101000
    BELDEN
    #18 FFEP SH FEP
89120 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 89120 Coax - CATV Cable For more Information please call 1-800-Belden1 General Description: 18 AWG solid .040" bare copper-covered steel conductor, foam FEP insulation, Duofoil® (100% coverage) plus a tinned copper braid shield (95% coverage), FEP jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 18 Solid Dia. (in.) BCCS - Bare Copper Covered Steel .040 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) FFEP - Foam Fluorinated Ethylene Propylene .170 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material FEP - Fluorinated Ethylene Propylene Overall Cable Overall Nominal Diameter: 0.234 in. Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C Bulk Cable Weight: 43 lbs/1000 ft. Max. Recommended Pulling Tension: 141 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CATVP, CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Series Type: Series 6 Flame Test UL Flame Test: NFPA 262 Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 89120 Coax - CATV Cable CSA Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Plenum Number: 87120, 82120 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .09 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.5 Nominal Velocity of Propagation: VP (%) 82 Nominal Delay: Delay (ns/ft) 1.24 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 28.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.7 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .3 10 .66 50 1.6 100 2.2 200 3.0 400 4.6 700 6.6 900 7.7 1000 8.2 Max. Operating Voltage - UL: Voltage 300 V RMS Minimum Structural Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 400 20 Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 89120 0101000 1,000 FT 46.000 LB BLACK C #18 FFEP SH FEP 89120 010500 500 FT 23.000 LB BLACK C #18 FFEP SH FEP Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 08-28-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 89120 Coax - CATV Cable product. Page 3 of 3 08-26-2016
89120 0101000 价格&库存
很抱歉,暂时无法提供与“89120 0101000”相匹配的价格&库存,您可以联系我们找货
