9269 003U1000
9269 003U1000
    BELDEN
    COAX RG-62A/U 22AWG 93 OHM
9269 003U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9269 Coax - 93 Ohms For more Information please call 1-800-Belden1 General Description: 22 AWG solid .025" bare copper-covered steel conductor, semi-solid polyethylene insulation, bare copper braid shield (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 22 Solid Dia. (in.) BCCS - Bare Copper Covered Steel .025 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) Semi-Solid PE - Semi-Solid Polyethylene 0.026 0.146 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.032 Overall Cable Overall Nominal Diameter: 0.239 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 60°C (UL AWM Style 1478) Bulk Cable Weight: 36 lbs/1000 ft. Max. Recommended Pulling Tension: 84 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2, CM CEC/C(UL) Specification: CM AWM Specification: UL Style 1478 (30 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes PMSHA Specification: SC-182/3 Customer Part Number Reference Specification: IBM P/N 323921 Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9269 Coax - 93 Ohms Customer Part Number Reference Specification: IBM P/N 323921 RG Type: 62A/U Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 89269, 87269, 82269 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 93 Nom. Inductance: Inductance (µH/ft) 0.116 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 13.5 Nominal Velocity of Propagation: VP (%) 84 Nominal Delay: Delay (ns/ft) 1.21 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 41.2 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.9 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.3 10 0.9 50 1.9 100 2.7 200 3.8 400 5.3 700 7.3 900 8.2 1000 8.7 Max. Operating Voltage - UL: Voltage Description 300 V RMS CM 150 V RMS CL2 30 V RMS AWM Style 1478 Max. Operating Voltage - Non-UL: Voltage 750 V RMS Put Ups and Colors: Item # Putup Ship Weight Color 9269 A8RU1000 1,000 FT 36.000 LB BEIGE, SNOW Notes Item Desc RG-62A/U TYPE COAX 9269 003U1000 1,000 FT 36.000 LB ORANGE RG-62A/U TYPE COAX 9269 010U1000 1,000 FT 36.000 LB BLACK RG-62A/U TYPE COAX 9269 010U500 500 FT 18.500 LB BLACK RG-62A/U TYPE COAX 306 2.09 9269 0101000 1,000 FT 38.000 LB BLACK 9269 0101640 1,640 FT 60.680 LB BLACK C RG-62A/U TYPE COAX 9269 0102000 2,000 FT 76.000 LB BLACK C RG-62A/U TYPE COAX 9269 0103280 3,280 FT 121.360 LB BLACK C RG-62A/U TYPE COAX 9269 010500 500 FT 19.000 LB BLACK C RG-62A/U TYPE COAX 9269 0105000 5,000 FT 185.000 LB BLACK C RG-62A/U TYPE COAX RG-62A/U TYPE COAX Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9269 Coax - 93 Ohms 9269 060U1000 1,000 FT 36.000 LB CHROME RG-62A/U TYPE COAX Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-16-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9269 003U1000 价格&库存
很抱歉,暂时无法提供与“9269 003U1000”相匹配的价格&库存,您可以联系我们找货
