Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
9399 Multi-Conductor - Two-Conductor, Low-Impedance Cables
For more Information
please call
1-800-Belden1
General Description:
24 AWG stranded (45x40) BC alloy conductors, EPDM rubber insulation, conductive textile wrap (100%
coverage), TC braid shield (65% coverage), cotton spiral, EPDM jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material Dia. (in.)
2
24
45x40
Bare Copper Alloy
.024
Total Number of Conductors:
2
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
EPDM - Ethylene Propylene Diene Monomer Rubber 0.064
Outer Shield
Outer Shield Material:
Layer # Type
Outer Shield Material Coverage (%)
1
Tape
Conductive Textile
100
2
Braid
TC - Tinned Copper
65
3
Spiral Serve Cotton
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
EPDM - Ethylene Propylene Diene Monomer Rubber .020
Overall Cable
Overall Nominal Diameter:
0.200 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +90°C
Non-UL Temperature Rating:
90°C
Bulk Cable Weight:
25 lbs/1000 ft.
Max. Recommended Pulling Tension:
48 lbs.
Min. Bend Radius/Minor Axis:
2 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2002/95/EC (RoHS):
No
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
55
Nom. Inductance:
Inductance (µH/ft)
0.019
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
30
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
55
Page 1 of 2
01-05-2017
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
28.7
Nominal Outer Shield DC Resistance:
11.38
Max. Operating Voltage - Non-UL:
Voltage
300 V RMS
Max. Recommended Current:
Current
2.2 Amps per conductor @ 25°C
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
9399 001500
500 FT
12.500 LB
BROWN
C
2 #24 EPDM BRD EPDM
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 2
Revision Date: 08-22-2012
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
01-05-2017
很抱歉,暂时无法提供与“9399 001500”相匹配的价格&库存,您可以联系我们找货
