9406 T35U1000
9406 T35U1000
    BELDEN
    CBL 2PR 22AWG SHLD
9406 T35U1000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9406 Multi-Conductor - Audio, Control and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductors, semi-rigid PVC insulation, twisted pairs, individually shielded w/Beldfoil® (100% coverage), 22 AWG stranded TC drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 22 7x30 TC - Tinned Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Wall Thickness (mm) S-R PVC - Semi-Rigid Polyvinyl Chloride 0.279 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® (Z-Fold®) Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 22 Inner Shield Drain Wire Stranding: 7x30 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.838 Overall Cable Overall Nominal Diameter: 4.394 x 7.112 mm Pair Pair Color Code Chart: Number Color 1 Black & White 2 Black & Yellow Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 2464) Page 1 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9406 Multi-Conductor - Audio, Control and Instrumentation Cable Bulk Cable Weight: 44.646 Kg/Km Max. Recommended Pulling Tension: 160.135 N Min. Bend Radius/Minor Axis: 44.450 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG AWM Specification: UL Style 2464 (300 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test C(UL) Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/m) 0.311695 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 164.05 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 311.695 Nominal Velocity of Propagation: VP (%) 60 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 49.215 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 42.653 Ohm/km Max. Operating Voltage - UL: Voltage 300 V RMS (UL AWM Style 2464) Max. Recommended Current: Current Page 2 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9406 Multi-Conductor - Audio, Control and Instrumentation Cable 2.3 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color 9406 T35U1000 305 MT 14.515 KG BEIGE, PALE FAWN Notes Item Desc 2 #22 FS PR PVC PVC 9406 T35U500 152 MT 7.484 KG BEIGE, PALE FAWN 2 #22 FS PR PVC PVC 9406 T35100 30 MT 1.724 KG BEIGE, PALE FAWN 9406 T351000 305 MT 14.969 KG BEIGE, PALE FAWN 9406 T35500 152 MT 7.711 KG BEIGE, PALE FAWN 2 #22 FS PR PVC PVC C 2 #22 FS PR PVC PVC 2 #22 FS PR PVC PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 11-05-2012 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 10-30-2013
9406 T35U1000 价格&库存
很抱歉,暂时无法提供与“9406 T35U1000”相匹配的价格&库存,您可以联系我们找货
