1
COPPERMedia
DATASheet
PS5E BIX DVO Outlet
PS5E DVO Workstation Outlets are available in
1, 2 and 4-port configurations in both flush
and surface mount styles. The workstation
outlets are robust and installer-friendly
products by design, combining punch-down
connectors with standard modular jacks. The
outlet’s unique completely enclosed housing
protects the connectors and allows the wires
to be front-terminated on BIX Insulation
Displacement Connectors (IDC). The snap-on
cover plate allows easy access and eliminates
visible mounting screw.
PS5E BIX DVO Outlets (for SF only)
PS5E DVO Workstation Outlets offer headroom
over the ANSI/TIA/EIA-568-B for Category 5e
Cabling standard.
Applications
> Telecommunications outlets in
the work areas.
Technical specifications
> Dimensions (H x W x D):
89 x 51 x 32 mm (3.5 x 2.0 x 1.25 in.).
> Materials:
Housing and cover: fire-retardant plastic,
UL94V-0, gray, almond, white or black
Connector module: printed circuit board,
modular jacks and IDC connectors
IDC Connector:
Features & Benefits
> Exceeds Category 5e performance providing
additional margin to support emerging
gigabit applications
> Available in T568A-ISDN and T568B-ALT
wiring patterns for simple wire termination
according to the standard color-code
sequence (Blue, Orange, Green, Brown)
> Robust and installer-friendly design to
reduce installation and operating costs
IDC clip material: phosphor bronze with tin
plating over nickel
Housing material: fire-retardant plastic,
UL94V-0
Quiet front, with fully recessed clips
Housing color: blue for T568A-ISDN or
orange for T568B-ALT.
Modular Jack:
> Fully enclosed connector module in plastic
housing for better protection
Contact material: phosphore bronze with
50 micro-inches gold over nickel.
> Front-access wire termination for
trouble-free installation, testing and
maintenance
> Snap-on cover mechanism eliminating
visible mounting screws
> Color coding and service identification
labeling option at each port using icons to
facilitate identification and ease network
management
> Available in surface and flush-mounted
versions, in 1, 2 and 4-port configurations
for greater installation flexibility.
1-800-BELDEN-1
www.belden.com
2
COPPERMedia
DATASheet
PS5E BIX DVO Outlet
Mechanical Characteristics
Electrical Characteristics
Packaging
> IDC Termination Interface:
> Dielectric strength: 1,000 V RMS
at 60 Hz for 1 minute
> Individually packaged in a clear plastic
bag, including mounting screws
(surface mount includes double-sided
tape)
Gas-tight connection – insulation slicing
of 22, 24 and 26 AWG (0.64, 0.5 and
0.4 mm) plastic insulated solid copper
conductors
> Current rating: 1.5 A maximum
> Insulation resistance: 200 MΩ minimum
> Contact resistance: 1 mΩ per contact.
Durability: 200 insertions of any
combination of wire gauge
4-pair printed circuit board mounted IDC
connector type
Compatible with the BIX Connecting Tool
(sold separately).
Modular Jack:
8-pin connector, FCC part 68, Subpart F
compliant
Durability: 1000 mating cycles.
> Standard shipping carton of 50 units
> Surface mount includes double-side
tape.
Installation tips
> Verify clearence space and select the
oppropriate electrical box or mounting
frame prior to installing
> Mount the outlet housing on the wall
prior to termination
> Label each port carefully for future
reference and ease of administration
> Use different colored icons to ease
identification and location of users, areas
or types of service
For More Information
For any other product information call:
1-800-BELDEN-1 or visit us at
www.Belden.com
All information is subject to change
without notice, since Belden reserves
the right to change its products as progress
in engineering and manufacturing methods
or other circumstances may warrant.
> Unlatch the cover by inserting and
twisting a flat screwdriver in the
opening at the bottom or the side of
the cover.
Ordering Information
PS5E BIX DVO Outlet
DETAIL
1-port
2-port
4-port
1-port
2-port
4-port
1-port
2-port
4-port
1-port
2-port
COLOR
ORDERING NUMBER
ORDERING NUMBER
Gray
Gray
Gray
Almond
Almond
Almond
White
White
White
Black
Black
SURFACE
AX100382
AX100390
AX100398
AX100383
AX100391
AX100399
AX100384
AX100392
AX100400
AX100385
AX100393
FLUSH
AX100334
AX100342
AX100350
AX100335
AX100343
AX100351
AX100336
AX100344
AX100352
AX100337
AX100345
1-800-BELDEN-1
www.belden.com
很抱歉,暂时无法提供与“AX100382”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+400.684352+51.83464
