AX101792
AX101792
    BELDEN
    OPTIMAX SC SINGLEMODE
AX101792 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101792 Modular Connectors - Optimax Connector For more Information please call 1-800-Belden1 General Description: Optimax Field Installable Connector, SC, Single-mode (OS2), for 900 µm tight buffered fiber Usage (Overall) Suitable Applications: Indoor termination of fiber cables: Patch panels, Communication outlets, Fiber-to-the-desk, Distribution frames, Direct termination to equipment, Fiber cable repair, Campus, Customer premise / Access network, Data Centers Related Parts: Accessory kit for jacketed termination, Installation Tool kits, Breakout kits Physical Characteristics (Connectivity) Dimensions Dimensions: Height (in.) Width (in.) Length (in.) 0.362 0.394 1.752 Materials Materials: Description Type Material Color Connector Body N/A Plastic Blue Included Parts Included Parts: 900 micron boot Packaging Packaging: Individually packaged in a plastic bag. Standard pack of 5 units, 500 units/box Mechanical Characteristics (Connectivity) Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Mechanical Specifications: Parameters Specifications Interconnection Compatibility LC, SC and ST-Compatible connectors Field Assembly Time 1 minute for 900 µm, 3 minutes for jacketed fiber Durability (Multimode) Less than 0.2 dB change, 500 cycles Durability (Single-mode) Less than 0.3 dB change, 500 cycles Nominal Fiber OD 125 µm Storage Temperature -40°F to 149°F (-40°C to 65°C) Operating Temperature 32°F to 145°F (0°C to 60°C) Tensile Load on jacketed fiber 50 N (11.2 lbs. / 5.1 Kg) Tensile Load on 900 micron tight buffered fiber 6.7 N (1.5 lbs. / 0.68 Kg) Ferrule Ceramic Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2006 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: TIA 568.C.3 Safety Listing: ACA Suitability Suitability - Indoor: Yes - Indoor Transmission Characteristics (Connectivity) Transmission Specifications: Page 1 of 2 09-11-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101792 Modular Connectors - Optimax Connector Parameters Specifications Insertion Loss (Multimode and Single-mode) 0.3 dB (typical) Reflectance (Multimode) -30 dB (typical) Reflectance (Single-mode) -40 dB (guaranteed) Notes (Overall) Notes: Please see Installation Instruction Manual AX103148 (included in Installation Tool Kits, reference to NP271) Notes (Cont'd.): For Optimax termination on jacketed fibers, please use the appropriate Accessory Kit LC - AX101984 SC AX101794 ST - AX101793 Product Family Part Number List: Description Belden Part Number LC 62.5 µm, Multimode AX101981 LC 50 µm, Multimode AX101982 LC Single-mode AX101983 SC 62.5 µm, Multimode AX100029 SC 50 µm, Multimode AX101077 SC Single-mode AX101792 ST Compatible 62.5 µm, Multimode A0408835 ST Compatible 50 µm, Multimode AX101075 ST Compatible Single-mode AX101791 Put Ups and Colors: Item # Putup Ship Weight AX101792 1 EA 0.007 LB Revision Number: 0 Color Notes Item Desc OPTIMAX SC SINGLEMODE Revision Date: 12-03-2010 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 09-11-2017
AX101792 价格&库存
很抱歉,暂时无法提供与“AX101792”相匹配的价格&库存,您可以联系我们找货
