BE43769.00305
BE43769.00305
    BELDEN
    BELDEN - BE43769.00305 - Networking Cable, RailTuff® Profinet, LSZH, 2 Pair, Screened, Cat5e, 22 AWG...
BE43769.00305 数据手册
Part Number: BE43769 RailTuff Cat 5e, PROFINET, AWG 22 (19) Product Description RailTuff Railway Approved Cat 5e, PROFINET, AWG 22(19), HiFlex, Premium Cross-linked LSNH Insulation and Jacket, Heavy Shielded, DIN 5510-2 level 1 to 4, EN 50155 Flame Resistance acc EN/TS 45545, IEC 60332-1-2, EN 50305 & IEC 60332-3-25 cat D, EN/TS 45545 (Class R15 and R16 HL3), Oil Resistance Technical Specifications Product Overview Environmental Space: Indoor Suitable Applications: For use in railway applications such as rolling stock, buses or other vehicles, cable meets the requirements of the relevant parst of international railway standars like DIN 5510-2, EN 50153, EN 50155, EN 50305 and CEN/TS 45545 Physical Characteristics (Overall) Conductor AWG Stranding 22 Stranded Material Construction n x D No. of Conductors TC - Tinned Copper 19x0.15 mm 4 Conductor, Table Note: IEC 60228 class 5 Conductor Count: 4 Total Number of Pairs: 2 Conductor Size: 22 AWG Insulation Material Nominal Diameter Diameter +/- Tolerance PO - Polyolefin 1.63 mm 0.05 mm Color Chart Number Color Quad 1 White & Blue & Yellow & Orange Inner Jacket Material Material Nominal Diameter FRNC / LSZH Bedding 4.3 mm Outer Shield Material Type Material Thickness of Foil Min. Coverage [%] Tape Aluminum/Polyester 50 / 23 µm Braid TC - Tinned Copper 80 % Outer Jacket Material Material Color Nominal Diameter Diameter +/- Tolerance Min. Wall Thickness Cross-linked LSZH / FRNC Black 6.7 mm Construction and Dimensions Cabling Description 1 quad with center filler Electrical Characteristics 0.3 mm 0.8 mm Conductor DCR Max. Conductor DCR 57.1 Ohm/km Shielding: SF/UTP - Overall Braid + Foil Impedance Frequency [MHz] Nominal Characteristic Impedance Nominal Characteristic Tolerance 1 - 100 100 Ohm 15 Ohm Delay Max. Delay Nominal Velocity of Propagation (VP) [%] 530 ns/100m 66 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) Min. NEXT [dB] Min. FEXT 1 MHz 2.1 dB/100m 65.3 dB 64 dB 4 MHz 4.1 dB/100m 56.3 dB 52 dB 10 MHz 6.5 dB/100m 50 dB 43.8 dB 16 MHz 8.3 dB/100m 47 dB 40 dB 31.25 MHz 11.7 dB/100m 42.9 dB 33.9 dB 62.5 MHz 17 dB/100m 38.4 dB 28 dB 100 MHz 22 dB/100m 35.3 dB 24 dB Transfer Impedance Frequency [MHz] Transfer Impedance 10 Mhz Max. 10 mOhm/m Voltage Voltage Rating [V] 300 V Temperature Range Installation Temp Range: -5°C To +50°C Storage Temp Range: -40°C To +90°C Operating Temp Range: -40°C To +90°C Mechanical Characteristics Oil Resistance: IEC 60811-2-1 Bulk Cable Weight: 68 kg/km Min Bend Radius (W/o Pulling Strength): 67 mm Min Setting Radius: 33.5 mm No Adherance Wire to Wire/Wire to Jacket: No adherance Standards CENELEC Compliance: EN 50153, EN 50155 and EN 50305 Data Category: Category 5e Other Specification: EN 50306 par 4.8 + 4.9 + 4.10 (1.5 kV/1min); Toxicity index to NF X70-100 CITc Max. 0.7 CEN/TS 45545 (Class R14 HL 3) Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1-2 and IEC 60332-3-25 Fire Resistance (CI, Time to Failure): DIN 5510-2 protection level 1 to 4 Other Flammability: DIN 5510 protection level 1 to 4 ; EN 50305 Amount of Halogen acc. to IEC 60754-1 & EN50267-1: Zero Part Number Variants Item # Color BE43769.00305 Black BE43769.00500 Black Patent: https://www.belden.com/resources/patents History Revision Number: 5 © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
BE43769.00305 价格&库存
很抱歉,暂时无法提供与“BE43769.00305”相匹配的价格&库存,您可以联系我们找货
