C3GBCY-KC50
C3GBCY-KC50
    BELDEN
    BELDEN - C3GBCY-KC50 - Multicore Cable, Screened, 3 Core, 0.75 mm², 164 ft, 50 m
C3GBCY-KC50 数据手册
MachFlex 375 CY Cables Shielded (CY) PVC Control Cables Tinned Copper Braid Shield (TCB) Excellent Noise Immunity Applications Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more. General Reference Standards • • • • • DIN VDE 0295, IEC 60228, BS6360 DIN EN 50290-2-22, DIN VDE 0207-363-4-1 IEC 60227-5, VDE 0281 DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 RoHS & REACH Directives Construction and Performance 1. Conductor Material Stranded bare copper (DIN VDE 0295 Class 5) 2. Insulation Material & Color PVC (polyvinyl chloride). A) AA) Up to 5 cores: color-coded. From 6 cores: Belden MachFlex Color code. B) G = with GN-YE protective conductor; X = without protective conductor. 3. Braid Shield Material Tinned Copper Braid Shield 4. Jacket / Sheath Material PVC (polyvinyl chloride) 5. Flame Retardancy VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 6. Voltage Rating (Uo/U) Up to 1.5 mm2: 300 / 500 V From 2.5 mm2: 450 / 750 V 7. Oil Resistant DIN EN 50290-2-22 (TM54) 8. Temperature Range -5 °C TO +70 °C (Occasional movement) -40 °C TO +80 °C (Fixed installation) 9. Bending Radius 20 x OD (Occasional movement) 6 x OD (Fixed installation) 10. Other Properties Good UV resistance, chemical resistance & flexibility MachFlex 375 CY Shielded (CY) PVC Control Cables TINNED COPPER BRAID SHIELDED CABLE WITH (G) PROTECTIVE GROUND 5 4 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.2 7.7 8.3 8.9 11.3 13.9 1 = Conductor 2 = Insulation 3 = Inner Sheath 4 = Tinned Copper Braid Shielded 5 = Outer Sheath Conductor 0.75 mm2 Copper Weight (kg/km) 45.08 53.90 64.68 78.40 135.73 226.25 EMEA Part Code C3GACY C4GACY C5GACY C7GACY C12GACY C20GACY APAC Part Code C3G0.5CY C4G0.5CY C5G0.5CY C7G0.5CY C12G0.5CY C20G0.5CY Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.7 8.3 9.0 9.7 12.4 15.2 Copper Weight (kg/km) 55.86 62.72 75.46 99.96 173.46 289.10 EMEA APAC Part Code Part Code C3GBCY C3G0.75CY C4GBCY C4G0.75CY C5GBCY C5G0.75CY C7GBCY C7G0.75CY C12GBCY C12G0.75CY C20GBCY C20G0.75CY Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.2 63.70 4 8.8 76.44 5 9.6 87.22 7 10.3 110.74 12 13.4 184.34 20 16.3 307.23 Conductor 2.50 mm2 EMEA Part Code C3GCCY C4GCCY C5GCCY C7GCCY C12GCCY C20GCCY APAC Part Code C3G1.0CY C4G1.0CY C5G1.0CY C7G1.0CY C12G1.0CY C20G1.0CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.8 77.42 4 9.5 95.06 5 10.3 113.68 7 11.1 146.02 12 14.5 274.40 20 17.7 457.33 Conductor 4.00 mm2 EMEA Part Code C3GDCY C4GDCY C5GDCY C7GDCY C12GDCY C20GDCY APAC Part Code C3G1.5CY C4G1.5CY C5G1.5CY C7G1.5CY C12G1.5CY C20G1.5CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 12.0 143.08 4 13.3 163.66 5 14.5 196.00 7 15.8 282.24 9 19.2 362.88 12 20.8 467.75 Conductor 6.00 mm2 EMEA Part Code C3GECY C4GECY C5GECY C7GECY C9GECY C12GECY APAC Part Code C3G2.5CY C4G2.5CY C5G2.5CY C7G2.5CY C9G2.5CY C12G2.5CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 13.7 174.20 4 15.1 232.26 5 16.5 274.40 7 18.0 384.16 9 22.0 493.92 12 24.0 658.56 Conductor 10.00 mm2 EMEA Part Code C3GFCY C4GFCY C5GFCY C7GFCY C9GFCY C12GFCY APAC Part Code C3G4CY C4G4CY C5G4CY C7G4CY C9G4CY C12G4CY No. of Cores 3 4 5 7 9 EMEA Part Code C3GGCY C4GGCY C5GGCY C7GGCY C9GGCY APAC Part Code C3G6CY C4G6CY C5G6CY C7G6CY C9G6CY No. of Cores 3 4 5 7 9 EMEA Part Code C3GHCY C4GHCY C5GHCY C7GHCY C9GHCY APAC Part Code C3G10CY C4G10CY C5G10CY C7G10CY C9G10CY EMEA Part Code C3GJCY C4GJCY C5GJCY APAC Part Code C3G25CY C4G25CY C5G25CY Nom. Overall Diameter (mm) 15.3 16.8 18.4 20.1 24.9 Copper Weight (kg/km) 233.73 311.64 432.18 519.40 667.80 Conductor 16.00 mm2 No. of Cores 3 4 5 Nom. Overall Diameter (mm) 22.5 24.9 27.4 Copper Weight (kg/km) 594.86 787.92 916.30 Nom. Overall Diameter (mm) 17.9 19.8 21.7 24.0 29.6 Copper Weight (kg/km) 355.15 507.64 583.10 780.08 1,004.24 Conductor 25.00 mm2 EMEA Part Code C3GICY C4GICY C5GICY APAC Part Code C3G16CY C4G16CY C5G16CY No. of Cores 3 4 5 Nom. Overall Diameter (mm) 25.4 28.1 30.8 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 853.33 1,137.78 1,372.00 MachFlex 375 CY Shielded (CY) PVC Control Cables TINNED COPPER BRAID SHIELDED CABLE WITHOUT (G) PROTECTIVE GROUND 5 4 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.2 7.7 8.3 8.9 11.3 13.9 1 = Conductor 2 = Insulation 3 = Inner Sheath 4 = Tinned Copper Braid Shielded 5 = Outer Sheath Conductor 0.75 mm2 Copper Weight (kg/km) 45.08 53.90 64.68 78.40 135.73 226.25 EMEA Part Code C3XACY C4XACY C5XACY C7XACY C12XACY C20XACY APAC Part Code C3X0.5CY C4X0.5CY C5X0.5CY C7X0.5CY C12X0.5CY C20X0.5CY Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.7 8.3 9.0 9.7 12.4 15.2 Copper Weight (kg/km) 55.86 62.72 75.46 99.96 173.46 289.10 EMEA Part Code C3XBCY C4XBCY C5XBCY C7XBCY C12XBCY C20XBCY APAC Part Code C3X0.75CY C4X0.75CY C5X0.75CY C7X0.75CY C12X0.75CY C20X0.75CY Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.2 63.70 4 8.8 76.44 5 9.6 87.22 7 10.3 110.74 12 13.4 184.34 20 16.3 307.23 Conductor 2.50 mm2 EMEA Part Code C3XCCY C4XCCY C5XCCY C7XCCY C12XCCY C20XCCY APAC Part Code C3X1.0CY C4X1.0CY C5X1.0CY C7X1.0CY C12X1.0CY C20X1.0CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.8 77.42 4 9.5 95.06 5 10.3 113.68 7 11.1 146.02 12 14.5 274.40 20 17.7 457.33 Conductor 4.00 mm2 EMEA Part Code C3XDCY C4XDCY C5XDCY C7XDCY C12XDCY C20XDCY APAC Part Code C3X1.5CY C4X1.5CY C5X1.5CY C7X1.5CY C12X1.5CY C20X1.5CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 12.0 143.08 4 13.3 163.66 5 14.5 196.00 7 15.8 282.24 9 19.2 362.88 12 20.8 467.75 Conductor 6.00 mm2 EMEA Part Code C3XECY C4XECY C5XECY C7XECY C9XECY C12XECY APAC Part Code C3X2.5CY C4X2.5CY C5X2.5CY C7X2.5CY C9X2.5CY C12X2.5CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 13.7 174.20 4 15.1 232.26 5 16.5 274.40 7 18.0 384.16 9 22.0 493.92 12 24.0 658.56 Conductor 10.00 mm2 EMEA Part Code C3XFCY C4XFCY C5XFCY C7XFCY C9XFCY C12XFCY APAC Part Code C3X4CY C4X4CY C5X4CY C7X4CY C9X4CY C12X4CY No. of Cores 3 4 5 7 9 EMEA Part Code C3XGCY C4XGCY C5XGCY C7XGCY C9XGCY APAC Part Code C3X6CY C4X6CY C5X6CY C7X6CY C9X6CY No. of Cores 3 4 5 7 9 EMEA Part Code C3XHCY C4XHCY C5XHCY C7XHCY C9XHCY APAC Part Code C3X10CY C4X10CY C5X10CY C7X10CY C9X10CY EMEA Part Code C3XJCY C4XJCY C5XJCY APAC Part Code C3X25CY C4X25CY C5X25CY Nom. Overall Diameter (mm) 15.3 16.8 18.4 20.1 24.9 Copper Weight (kg/km) 233.73 311.64 432.18 519.40 667.80 Conductor 16.00 mm2 No. of Cores 3 4 5 Nom. Overall Diameter (mm) 22.5 24.9 27.4 Copper Weight (kg/km) 594.86 787.92 916.30 Nom. Overall Diameter (mm) 17.9 19.8 21.7 24.0 29.6 Copper Weight (kg/km) 355.15 507.64 583.10 780.08 1,004.24 Conductor 25.00 mm2 EMEA Part Code C3XICY C4XICY C5XICY APAC Part Code C3X16CY C4X16CY C5X16CY No. of Cores 3 4 5 Nom. Overall Diameter (mm) 25.4 28.1 30.8 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 853.33 1,137.78 1,372.00
C3GBCY-KC50 价格&库存
很抱歉,暂时无法提供与“C3GBCY-KC50”相匹配的价格&库存,您可以联系我们找货
C3GBCY-KC50
    • 1+904.57713
    • 5+868.39946
    库存:150
    C3GBCY-KC50
      库存:150
      C3GBCY-KC50
      • 1+27.809961+3.60470
      • 25+23.0151425+2.98320
      • 50+20.4869650+2.65550
      • 100+18.04596100+2.33910
      库存:1
