C3GC-B100
C3GC-B100
    BELDEN
    BELDEN - C3GC-B100 - Multicore Cable, Unscreened, 3 Core, 1 mm², 328 ft, 100 m
C3GC-B100 数据手册
MachFlex 375 YY Cables Unshielded PVC Control Cables Applications Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more. General Reference Standards • • • • • DIN VDE 0295, IEC 60228, BS6360 DIN EN 50290-2-22, DIN VDE 0207-363-4-1 IEC 60227-5, EN 50525-2-51 DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 RoHS & REACH & CE Directives Construction and Performance 1. Conductor Material Stranded bare copper (DIN VDE 0295 Class 5) 2. Insulation Material & Color PVC (polyvinyl chloride). A) Up to 5 cores: color-coded. From 6 cores: Belden MachFlex Color code. B) G = with GN-YE protective conductor; X = without protective conductor. 3. Braid Shield Material Tinned Copper Braid Shield 4. Jacket / Sheath Material PVC (polyvinyl chloride) 5. Flame Retardancy VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 6. Voltage Rating (Uo/U) Up to 1.5 mm2: 300 / 500 V From 2.5 mm2: 450 / 750 V 7. Oil Resistant DIN EN 50290-2-22 (TM54) 8. Temperature Range -5 °C TO +70 °C (Occasional movement) -40 °C TO +80 °C (Fixed installation) 9. Bending Radius 10 x OD (Occasional movement) 4 x OD (Fixed installation) 10. Other Properties Good UV resistance, chemical resistance & flexibility MachFlex 375 YY Unshielded PVC Control Cables UNSHIELDED CABLE WITH (G) PROTECTIVE GROUND 1 = Conductor 2 = Insulation 3 = Sheath 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 5.1 5.6 6.2 6.8 9.1 11.4 Conductor 0.75 mm2 Copper Weight (kg/km) 14.40 19.20 24.00 33.60 58.00 96.70 EMEA Part Code C3GA C4GA C5GA C7GA C12GA C20GA APAC Part Code C3G0.5 C4G0.5 C5G0.5 C7G0.5 C12G0.5 C20G0.5 Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 5.6 6.2 6.8 7.5 10.1 12.7 Copper Weight (kg/km) 21.60 28.80 36.00 50.00 86.00 143.30 EMEA Part Code C3GB C4GB C5GB C7GB C12GB C20GB APAC Part Code C3G0.75 C4G0.75 C5G0.75 C7G0.75 C12G0.75 C20G0.75 Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 6.1 28.80 4 6.7 38.40 5 7.4 48.00 7 8.1 67.00 12 10.9 115.00 20 13.8 192.00 Conductor 2.50 mm2 EMEA Part Code C3GC C4GC C5GC C7GC C12GC C20GC APAC Part Code C3G1.0 C4G1.0 C5G1.0 C7G1.0 C12G1.0 C20G1.0 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 6.6 43.00 4 7.3 58.00 5 8.1 72.00 7 8.9 101.00 12 12.0 173.00 20 15.1 288.30 Conductor 4.00 mm2 EMEA Part Code C3GD C4GD C5GD C7GD C12GD C20GD APAC Part Code C3G1.5 C4G1.5 C5G1.5 C7G1.5 C12G1.5 C20G1.5 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 9.8 72.00 4 10.9 96.00 5 12.0 120.00 7 13.3 168.00 9 16.6 216.00 12 18.1 288.00 Conductor 6.00 mm2 EMEA Part Code C3GE C4GE C5GE C7GE C9GE C12GE APAC Part Code C3G2.5 C4G2.5 C5G2.5 C7G2.5 C9G2.5 C12G2.5 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 11.3 115.00 4 12.6 154.00 5 13.9 192.00 7 15.4 269.00 9 19.3 345.90 12 21.0 461.00 Conductor 10.00 mm2 EMEA Part Code 3GF 4GF 5GF 7GF C9GF C12GF APAC Part Code C3G4 C4G4 C5G4 C7G4 C9G4 C12G4 No. of Cores 3 4 5 7 9 EMEA Part Code C3GG C4GG C5GG C7GG C9GG APAC Part Code C3G6 C4G6 C5G6 C7G6 C9G6 No. of Cores 3 4 5 7 9 EMEA Part Code C3GH C4GH C5GH C7GH C9GH APAC Part Code C3G10 C4G10 C5G10 C7G10 C9G10 EMEA Part Code C3GJ C4GJ C5GJ APAC Part Code C3G25 C4G25 C5G25 Nom. Overall Diameter (mm) 12.8 14.2 15.8 17.4 21.9 Copper Weight (kg/km) 172.80 230.00 288.00 403.00 518.10 Conductor 16.00 mm2 No. of Cores 3 4 5 Nom. Overall Diameter (mm) 19.6 21.9 24.3 Copper Weight (kg/km) 460.50 614.00 768.00 Nom. Overall Diameter (mm) 15.3 17.1 19.0 21.0 26.4 Copper Weight (kg/km) 288.00 384.00 480.00 672.00 864.00 Conductor 25.00 mm2 EMEA Part Code C3GI C4GI C5GI APAC Part Code C3G16 C4G16 C5G16 No. of Cores 3 4 5 Nom. Overall Diameter (mm) 22.3 24.9 27.7 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 720.00 960.00 1,200.00 MachFlex 375 YY Unshielded PVC Control Cables UNSHIELDED CABLE WITHOUT (G) PROTECTIVE GROUND 1 = Conductor 2 = Insulation 3 = Sheath 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 5.1 5.6 6.2 6.8 9.1 11.4 Conductor 0.75 mm2 Copper Weight (kg/km) 14.40 19.20 24.00 33.60 58.00 96.70 EMEA Part Code C3XA C4XA C5XA C7XA C12XA C20XA APAC Part Code C3X0.5 C4X0.5 C5X0.5 C7X0.5 C12X0.5 C20X0.5 Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 5.6 6.2 6.8 7.5 10.1 12.7 Copper Weight (kg/km) 21.60 28.80 36.00 50.00 86.00 143.30 EMEA Part Code C3XB C4XB C5XB C7XB C12XB C20XB APAC Part Code C3X0.75 C4X0.75 C5X0.75 C7X0.75 C12X0.75 C20X0.75 Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 6.1 28.80 4 6.7 38.40 5 7.4 48.00 7 8.1 67.00 12 10.9 115.00 20 13.8 192.00 Conductor 2.50 mm2 EMEA Part Code C3XC C4XC C5XC C7XC C12XC C20XC APAC Part Code C3X1.0 C4X1.0 C5X1.0 C7X1.0 C12X1.0 C20X1.0 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 6.6 43.00 4 7.3 58.00 5 8.1 72.00 7 8.9 101.00 12 12.0 173.00 20 15.1 288.30 Conductor 4.00 mm2 EMEA Part Code C3XD C4XD C5XD C7XD C12XD C20XD APAC Part Code C3X1.5 C4X1.5 C5X1.5 C7X1.5 C12X1.5 C20X1.5 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 9.8 72.00 4 10.9 96.00 5 12.0 120.00 7 13.3 168.00 9 16.6 216.00 12 18.1 288.00 Conductor 6.00 mm2 EMEA Part Code C3XE C4XE C5XE C7XE C9XE C12XE APAC Part Code C3X2.5 C4X2.5 C5X2.5 C7X2.5 C9X2.5 C12X2.5 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 11.3 115.00 4 12.6 154.00 5 13.9 192.00 7 15.4 269.00 9 19.3 345.90 12 21.0 461.00 Conductor 10.00 mm2 EMEA Part Code C3XF C4XF C5XF C7XF C9XF C12XF APAC Part Code C3X4 C4X4 C5X4 C7X4 C9X4 C12X4 No. of Cores 3 4 5 7 9 EMEA Part Code C3XG C4XG C5XG C7XG C9XG APAC Part Code C3X6 C4X6 C5X6 C7X6 C9X6 No. of Cores 3 4 5 7 9 EMEA Part Code C3XH C4XH C5XH C7XH C9XH APAC Part Code C3X10 C4X10 C5X10 C7X10 C9X10 EMEA Part Code C3XJ C4XJ C5XJ APAC Part Code C3X25 C4X25 C5X25 Nom. Overall Diameter (mm) 12.8 14.2 15.8 17.4 21.9 Copper Weight (kg/km) 172.80 230.00 288.00 403.00 518.10 Conductor 16.00 mm2 No. of Cores 3 4 5 Nom. Overall Diameter (mm) 19.6 21.9 24.3 Copper Weight (kg/km) 460.50 614.00 768.00 Nom. Overall Diameter (mm) 15.3 17.1 19.0 21.0 26.4 Copper Weight (kg/km) 288.00 384.00 480.00 672.00 864.00 Conductor 25.00 mm2 EMEA Part Code C3XI C4XI C5XI APAC Part Code C3X16 C4X16 C5X16 No. of Cores 3 4 5 Nom. Overall Diameter (mm) 22.3 24.9 27.7 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 720.00 960.00 1,200.00
C3GC-B100 价格&库存
很抱歉,暂时无法提供与“C3GC-B100”相匹配的价格&库存,您可以联系我们找货
C3GC-B100
  • 1+16.053401+2.07920
  • 25+13.2615025+1.71760
  • 50+11.8655650+1.53680
  • 100+10.55685100+1.36730
库存:470
