CPLCRBC-BR
CPLCRBC-BR
    BELDEN
    BELDEN - CPLCRBC-BR - Connector Accessory, Compression Tool
CPLCRBC-BR 数据手册
WWW.ICMCORP.NET CPLCRTC-B Compression Tool COMMERCIAL • Smaller, economical version of the RTC 360 tool • Manufactured of 4100 series aircraft grade Chromoly alloy for maximum strength and durability • Tool body is over molded with an ergonomic, hard plastic shell to ensure a comfortable grip and easy compression • Fixed compression dies inside the head of the tool allow for an easy, consistant compression • Compress with F-Conn’s Basic Series of F and RCA • Made in the USA • 1-year warranty Compression Tools INDUSTRY USE: CATV CPLCRBC-B Double Bubble™ Compression Tool INDUSTRY USE: SECURITY BROADCAST CATV COMMERCIAL • A perfect solution for structured wiring, security cameras, satellite and other exposed wiring installations • Manufactured of 4100 series aircraft grade Chromoly alloy • Compress with F-Conn’s DB™ Connector Series • Available in F, RCA and BNC • Creates a secure, permanent “double bubble” connection with the DB™ connector • Self-adjusting plunger head provides a precise and constant compression each and every time • Includes 1 interchangeable adapter tip for compression of F and RCA type connectors • Made in the USA • 1-year warranty Part# Description CPLCRBC-B Double Bubble™ Compression Tool - Blue LMTIP-S Silver adapter tip for F-Conn’s silver/nickel connectors RBCTIP-UHF Adapter tip for F-Conn’s 50 Ohm connectors Call for Tech Support 800.222.2142 23 WWW.ICMCORP.NET Compression Tools CPLCCT-SLM Linear Compliant Compression Tool INDUSTRY USE: PRO A/V SECURITY CATV COMMERCIAL • Manufactured of solid steel for maximum strength and durability • Crafted so that it is lightweight and easy to use • Self-adjusting plunger head provides a precise and constant compression each and every time • Includes four interchangeable adapter tips to compress a full line of connectors • Compress with F-Conn’s FS and RG Series Connectors • Made in the USA • 1-year warranty Part# Description CPLCCT-SLM Linear Complaint Compression Tool LMTIP-S Silver adapter tip for F-Conn’s silver/nickel connectors LMTIP-G Gold adapter tip for F-Conn’s gold connectors LMTIP-WP Wall Plate adapter tip for F-Conn’s splice connectors LMTIP-RA Right Angle adapter tip for F-Conn’s right angle connectors LMTIP-HOLDER Holder for adapter tips LMTIP-KIT Kit includes Holder + 5 tips - G, S, RA, WP, IEC CPLCCT-1-S Compression Tool INDUSTRY USE: CATV • For FS Series F-type and RCA compression connectors • No adjustment for compression! • Crafted so that it is lightweight and easy to use • Self-adjusting plunger head provides a precise and constant compression each and every time • Made in the USA • 1-year warranty 24 Call for Tech Support 800.222.2142 WWW.ICMCORP.NET CPLCCT-SS59/11 Compression Tool • Compress connectors for FS Series RG59, RG6, RG7 and RG11 cables with an easy flip of the die • Compress the F-Conn RG11 right angle connector • Compatible with other brands of compression connectors • Made in the USA • 1-year warranty Compression Tools INDUSTRY USE: CATV CPLCCT-11BNC Specialty Compression Tool INDUSTRY USE: CATV • Compresses the FS11BNC, RG11 BNC-type connector • No adjustments required! • Self-adjusting plunger head provides a precise and constant compression • Made in the USA • 1-year warranty CPLCRBC-ITS Specialty Compression Tool INDUSTRY USE: TOLL ROAD SECURITY • Designed specifically for the Double Bubble™ ITS BNC male & female connector • Designed for Belden 8281 & 8281B cable • Use the LMTIP-WP adapter tip for the DB59BNCSL2-F (female) splice ITS connector • Made in the USA • 1-year warranty Call for Tech Support 800.222.2142 25
CPLCRBC-BR 价格&库存
很抱歉,暂时无法提供与“CPLCRBC-BR”相匹配的价格&库存,您可以联系我们找货
