1808A B59500
1808A B59500
    BELDEN
    2 #30 FHDPE SRV PVC PVC
1808A B59500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1808A Coax - High-Flex S-Video Cable For more Information please call 1-800-Belden1 General Description: 30 AWG stranded (7x38) .012" tinned copper conductors, foam HDPE insulation, tinned copper serve shield (90% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 2 30 7x38 TC - Tinned Copper .013 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) FHDPE - Foam High Density Polyethylene .058 Inner Shield Inner Shield Material: Type Inner Shield Material Coverage (%) Spiral Serve TC - Tinned Copper 90 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride .100 Inner Jacket Color Code Chart: Number Color 1 Black 2 Yellow Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.254 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C UL Temperature Rating: 60°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 29 lbs/1000 ft. Max. Recommended Pulling Tension: 12 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 1354 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1808A Coax - High-Flex S-Video Cable EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.097 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.3 Nominal Velocity of Propagation: VP (%) 78 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 100.0 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 7.5 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .6 5 1.4 10 2.1 30 3.8 50 5.1 100 7.6 200 11.3 400 16.9 700 23.3 900 26.9 1000 28.6 Max. Operating Voltage - UL: Voltage 30 V RMS Max. Operating Voltage - Non-UL: Voltage 300 V RMS Notes (Overall) Notes: Inner Jacket Separator Material: Paper Tape. Put Ups and Colors: Item # Putup Ship Weight Color 1808A B59U1000 1,000 FT 31.000 LB BLACK, MATTE Notes Item Desc 1808A B59U500 500 FT 16.500 LB BLACK, MATTE 1808A B591000 1,000 FT 33.000 LB BLACK, MATTE C 2 #30 FHDPE SRV PVC PVC 1808A B59500 500 FT 16.500 LB BLACK, MATTE C 2 #30 FHDPE SRV PVC PVC 2 #30 FHDPE SRV PVC PVC 2 #30 FHDPE SRV PVC PVC Notes: C = CRATE REEL PUT-UP. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1808A Coax - High-Flex S-Video Cable Revision Number: 2 Revision Date: 10-04-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
1808A B59500 价格&库存
很抱歉,暂时无法提供与“1808A B59500”相匹配的价格&库存,您可以联系我们找货
