1858A B591000
1858A B591000
    BELDEN
    #15 GIFHDLDPE PVC TRIAX
1858A B591000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1858A Coax - RG-11/U Type For more Information please call 1-800-Belden1 General Description: 15 AWG stranded (19x27) .064" bare copper conductor, foam HDPE insulation, bare copper braid shields (95% coverage), Belflex® jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 15 19x27 BC - Bare Copper .064 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .312 Inner Shield Inner Shield Material: Type Inner Shield Material Coverage (%) Braid BC - Bare Copper 95 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PE - Polyethylene .391 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Belflex® PVC Blend - Polyvinyl Chloride Blend Overall Cable Overall Nominal Diameter: 0.520 in. Mechanical Characteristics (Overall) Operating Temperature Range: -35°C To +75°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 147 lbs/1000 ft. Max. Recommended Pulling Tension: 264 lbs. Min. Bend Radius/Minor Axis: 5.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1858A Coax - RG-11/U Type CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 11/U Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes - Black for Permanent Outdoor Installations; All Colors Suitable for Outdoor Field Deployable Use. Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.097 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.3 Nominal Velocity of Propagation: VP (%) 78 Nominal Delay: Delay (ns/ft) 1.30 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.1 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.8 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.4 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.100 3.600 0.300 10.000 0.500 71.500 1.200 135.000 1.800 270.000 2.600 360.000 3.100 540.000 3.900 720.000 4.700 750.000 4.800 1000.000 5.700 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Other Electrical Characteristic 1: Nominal Capacitance 1st Shield to 2nd Shield: 205 pf/ft. Other Electrical Characteristic 2: Nominal Voltage Breakdown: 20K V RMS Minimum Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5 850 21 Sweep Test Sweep Testing: 100% sweep tested 5 MHz to 850 MHz. Misc. Information (Overall) Put Ups and Colors: Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1858A Coax - RG-11/U Type Item # Putup Ship Weight Color Notes Item Desc 1858A B591000 1,000 FT 154.000 LB BLACK, MATTE C #15 GIFHDLDPE PVC TRIAX 1858A B594000 4,000 FT 648.000 LB BLACK, MATTE 1858A B59500 500 FT 80.500 LB BLACK, MATTE C #15 GIFHDLDPE PVC TRIAX 1858A 0021000 1,000 FT 154.000 LB RED C #15 GIFHDLDPE PVC TRIAX 1858A 002500 500 FT 80.500 LB RED C #15 GIFHDLDPE PVC TRIAX 1858A 0041000 1,000 FT 154.000 LB YELLOW C #15 GIFHDLDPE PVC TRIAX 1858A 004500 500 FT 80.500 LB YELLOW C #15 GIFHDLDPE PVC TRIAX 1858A 0051000 1,000 FT 154.000 LB GREEN, DARK C #15 GIFHDLDPE PVC TRIAX 1858A 0061000 1,000 FT 154.000 LB BLUE, LIGHT C #15 GIFHDLDPE PVC TRIAX 1858A 006500 500 FT 80.500 LB BLUE, LIGHT C #15 GIFHDLDPE PVC TRIAX #15 GIFHDLDPE PVC TRIAX Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 04-06-2009 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
1858A B591000 价格&库存
很抱歉,暂时无法提供与“1858A B591000”相匹配的价格&库存,您可以联系我们找货
1858A B591000
  • 1000+53.475601000+6.94016
