1875GB 006A1000
1875GB 006A1000
    BELDEN
    BELDEN - 1875GB 006A1000 - UNSHLD MULTIPR CABLE 4PR 1000FT 300V BLU
1875GB 006A1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1875GB Multi-Conductor - Enhanced Category 6 Bonded-Pair Patch Cables For more Information please call 1-800-Belden1 General Description: CAT6+ (350MHz), 4-Bonded-Pairs, U/UTP-Unshielded, Riser-CMR, Premise Patch Cable, 24 AWG Bonded Stranded (7x32) Tinned Copper Conductor, Polyolefin Insulation, PVC Jacket Usage (Overall) Suitable Applications: Premise Patch Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, Noisy Environments Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 7x32 TC - Tinned Copper, Bonded Strands Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.365 0.165 Outer Jacket Ripcord: No Overall Cable Overall Nominal Diameter: 0.365 x 0.165 in. Pair Pair Color Code Chart: Number Color For T568-B Wiring White/Brown Stripe & Brown White/Blue Stripe & Blue White/Green Stripe & Green White/Orange Stripe & Orange Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 29 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 0.500 in. Min. Bend/Installation: 1.600 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMR Page 1 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1875GB Multi-Conductor - Enhanced Category 6 Bonded-Pair Patch Cables CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 6 - TIA 568.C.2 Other Specification: UL Verified to Category 6 Patch Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: UL1666 Vertical Riser C(UL) Flame Test: FT4 CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15.0 Maximum Capacitance Unbalance (pF/100 m): 49.2 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 510 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 25 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) 1 2.0 74.3 72.3 70.3 70.3 20.0 4 4.1 65.3 63.3 59.2 59.2 23.0 8 5.8 60.3 58.8 53.0 53.0 24.5 10 6.5 59.3 57.3 51.0 51.0 25.0 16 8.2 56.3 54.3 46.0 46.0 25.0 20 9.3 54.8 52.8 43.5 43.5 25.0 25 10.4 53.4 51.4 41.0 41.0 24.3 31.25 11.7 51.9 49.9 38.2 38.2 23.6 62.5 17.0 47.4 45.4 28.4 28.4 21.5 100 22.0 44.3 42.3 25 25 21.0 Page 2 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1875GB Multi-Conductor - Enhanced Category 6 Bonded-Pair Patch Cables 155 30.2 41.5 39.5 14 14 21.0 200 34.8 39.8 37.8 10 10 21.0 250 39.6 38.3 36.3 3 3 18.0 300 46.7 37.2 34.2 0 0 18.0 310 47.6 36.9 34.9 18.0 350 51.1 36.2 34.2 17.0 400 55.3 35.3 33.3 14.0 500 63.3 33.8 31.8 14.0 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 12 100 ± 15 67.8 64.8 4 100 ± 12 100 ± 15 55.7 52.8 8 100 ± 12 100 ± 15 49.7 46.7 10 100 ± 12 100 ± 15 47.8 44.8 16 100 ± 12 100 ± 8 43.7 40.7 20 100 ± 12 100 ± 8 41.7 38.7 25 100 ± 15 100 ± 8 39.8 36.8 31.25 100 ± 15 100 ± 8 37.9 34.9 62.5 100 ± 15 100 ± 8 31.8 28.9 100 100 ± 15 100 ± 8 27.8 24.8 155 100 ± 15 100 ± 8 23.9 20.9 200 100 ± 15 100 ± 8 21.7 18.8 250 100 ± 20 100 ± 8 19.8 16.8 300 100 ± 20 100 ± 8 18.2 15.2 310 100 ± 20 100 ± 8 17.9 14.9 350 100 ± 22 100 ± 8 16.9 13.9 400 100 ± 32 100 ± 8 15.7 12.7 500 100 ± 32 100 ± 8 13.8 10.8 Notes (Overall) Notes: Jacket sequentially marked at 2 ft. intervals. Values above 350 MHz are information only. Third party verified to ANSI/TIA-568-C.2, Category 6 Patch RJ-45 Compatible Put Ups and Colors: Item # Putup Ship Weight Color 1875GB F2V1000 1,000 FT 31.000 LB GRAY, DEC Notes Item Desc 1875GB F6H1000 1,000 FT 31.000 LB GRAY, DARK PEARL C CAT6+ PATCH U/UTP CMR REEL 1875GB 0041000 1,000 FT 31.000 LB YELLOW C CAT6+ PATCH U/UTP CMR REEL 1875GB 005A1000 1,000 FT 32.000 LB GREEN, DARK CAT6+ PATCH U/UTP CMR RIB 1875GB 0051000 1,000 FT 31.000 LB GREEN, DARK CAT6+ PATCH U/UTP CMR REEL 1875GB 006A1000 1,000 FT 32.000 LB BLUE, LIGHT 1875GB 0061000 1,000 FT 31.000 LB BLUE, LIGHT 1875GB 007A1000 1,000 FT 32.000 LB VIOLET 1875GB 0091000 1,000 FT 31.000 LB WHITE 1875GB 0101000 1,000 FT 31.000 LB BLACK CAT6+ PATCH U/UTP CMR REEL CAT6+ PATCH U/UTP CMR RIB C CAT6+ PATCH U/UTP CMR REEL CAT6+ PATCH U/UTP CMR RIB CAT6+ PATCH U/UTP CMR REEL C CAT6+ PATCH U/UTP CMR REEL Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 02-28-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 02-01-2017
1875GB 006A1000 价格&库存
很抱歉,暂时无法提供与“1875GB 006A1000”相匹配的价格&库存,您可以联系我们找货
