37190 010250
37190 010250
    BELDEN
    HOOK-UP STR 1/0AWG EPDM
37190 010250 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 37190 Hook-up/Lead - UL AWM Style 3340 and 3374 For more Information please call 1-800-Belden1 General Description: EPDM high temperature lead wire. 150C EPDM wire is recommended for Class 130(B) , 155(F) and also in some 180(H) systems. It^s UL Recognized under Style 3374 as 150C-600V Appliance Wiring Material. The CSA Listing, as a coil lead, is 125C, 600V. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 1/0 262x24 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Min. Avg. Wall (in.) EPDM-Ethylene Propylene Diene Monomer Rubber 0.095 Separator Separator Material over Conductor: Y Overall Insulation Overall Cable Overall Nominal Diameter: 0.633 in. Mechanical Characteristics (Overall) Operating Temperature Range: -55°C To +150°C UL Temperature Rating: 125°C (UL AWM Style 3340), 125°C (UL AWM Style 3374), 150°C Bulk Cable Weight: 433 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL AWM Style: UL Style 3340 (600 V 125°C), UL Style 3374 (600 V 125°C) UL Rating: 600 V, 150°C CSA Rating: 600 V, 125°C CSA Type: CL1254 EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 0.100 Max. Operating Voltage - UL: Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 37190 Hook-up/Lead - UL AWM Style 3340 and 3374 Voltage Description 600 VRMS UL AWM 3340 600 VRMS UL AWM 3374 Max. Recommended Current: Description Current Single conductor in free air @ 30C ambient 339 amps Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 37190 010100 100 FT 48.300 LB BLACK C #1/0 STR EPDM 150C 600V 37190 010250 250 FT 115.500 LB BLACK CF #1/0 STR EPDM 150C 600V 37190 01050 50 FT 24.650 LB BLACK C #1/0 STR EPDM 150C 600V 37190 010500 500 FT 223.500 LB BLACK C 1/0 STR EPDM BLK Notes: C = CRATE REEL PUT-UP. F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50' Revision Number: 1 Revision Date: 08-30-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 01-05-2017
37190 010250 价格&库存
很抱歉,暂时无法提供与“37190 010250”相匹配的价格&库存,您可以联系我们找货
