Industrial Ethernet Cables
SF/UTP Cat 5e – 4 Pair Cables
A range of shielded copper cables for use in industrial Ethernet networks, designed to withstand the entire
spectrum of environmental and mechanical hazards, from temperature extremes and sunlight, to solvents,
oils, chemicals and moisture.
Ordering Information
Belden European Item Numbers
Jacket
Material
PVC
Premium FRNC
PUR (Halogen Free)
Performance
Cat 5e
Cat 5e
Cat 5e
Number
of Pairs
4 Pairs
4 Pairs
4 Pairs
Stationary
Application
74001E
74001NH
74001PU
Flexible
Application
ication
Appl
74002E
74002NH
74002PU
Highly Flexible
Application
74003PU
Applications
Industrial environments where IP67 may be required
Transmission of data in industrial applications via the ethernet protocol
Stationary applications, where there is no movement after installation
Flexible applications, subject to occasional movement or vibration after installation
Highly flexible, trailing applications, for instance ‘C Track’
Features & Benefits
• Choice of PVC, Premium FRNC or PUR cable jacket for specific application requirements in the harsh industrial environment
• High shield coverage to maintain signal integrity in the industrial ‘noisy’ environment
• Oil resistant
• Chemical & solvent resistant
• Temperature resistant
• Abrasion resistant
• Excellent mechanical resistance
• Weld-splatter resistant PUR cable jacket available on request
• IP67 rated
• UV resistant
• Black cable jacket
Construction & Dimensions
Mechanical Data – Stationary Application
Conductor (24AWG/1 - Solid Bare Copper)
2 Twisted, Polypropylene Insulated Conductors
- Pair 1 = White / Blue
- Pair 2 = White / Orange
- Pair 3 = White / Green
- Pair 4 = White / Brown
Foil Shield – Laminated Aluminium / Polyester
Braid Shield – Tinned Copper
Conductor
Insulation
(Nom. Dia.)
Braid
Coverage
Sheath
Material
Sheath
(Nom. Dia.)
Sheath
Colour
74001E
24AWG/1
1.10mm
>80%
PVC
7.00mm
Black
74001NH
24AWG/1
1.10mm
>80%
FRNC
7.00mm
Black
74001PU
24AWG/1
1.10mm
>80%
PUR
6.60mm
Black
Part Number
Mechanical Data – Flexible Application
Conductor (26AWG/7 – 7x0.16mm Stranded Tinned Copper)
Part Number
Conductor
Insulation
(Nom. Dia.)
Braid
Coverage
Sheath
Material
Sheath
(Nom. Dia.)
Sheath
Colour
74002E
26AWG/7
0.98mm
>80%
PVC
6.50mm
Black
74002NH
26AWG/7
0.98mm
>80%
FRNC
6.50mm
Black
74002PU
26AWG/7
0.98mm
>80%
PUR
6.50mm
Black
2
Mechanical Data – Highly Flexible Application
Conductor (26AWG/19 – 19x0.1mm Stranded Tinned Cu)
Part Number
Conductor
Insulation
(Nom. Dia.)
Braid
Coverage
Sheath
Material
Sheath
Sheath
(Nom. Dia.)
Sheath
Colour
74003PU
26AWG/19
1.00mm
>80%
PUR
6.65mm
Black
Standards
• ISO/IEC 11801 2
• ISO/IEC 24702
• EN 50173-1
• TIA/EIA-568-B.2
nd
Edition
Electrical Properties
450V A.C. / 300V D.C.
68%
< 5.34 ns / m
100 +/- 15 Ohm
Max Operating Voltage UL
Velocity of Propagation @ 4 – 100 MHz
Delay
Impedance @ 1 – 100 MHz
74001E / 74001NH / 74001PU (AWG24)
Frequency
(MHz)
1
4
10
16
31.25
62.5
100
Insertion Loss
(Max) (dB/100m)
2.0
4.1
6.5
8.2
9.3
10.4
11.7
17.0
22.0
NEXT
(dB)
65.3
56.3
50.3
47.2
45.8
44.3
42.9
38.3
35.3
ELFEXT
(dB/100m)
63.8
51.7
43.8
39.7
37.7
35.8
33.9
27.8
23.8
RETURN
RETURN
LOSS (dB)
20.0
23.0
25.0
25.0
25.0
24.3
23.6
21.5
20.1
3
74002E / 74002NH / 74002PU / 74003PU (AWG26)
Frequency
(MHz)
1
4
10
16
31.25
62.5
100
Insertion Loss
(Max) (dB/100m)
3.2
6.0
9.5
12.1
13.6
15.3
17.1
24.8
32
NEXT
(dB)
65.3
56.3
50.3
47.2
45.8
44.3
42.9
38.3
35.3
ELFEXT
(dB/100m)
63.8
51.7
43.8
39.7
37.7
35.8
33.9
27.8
23.8
RETURN
LOSS (dB)
20.0
23.0
25.0
25.0
25.0
24.3
23.6
21.5
20.1
Mechanical, Physical and/or Environmental Characteristics
Flame Resistance
Oil Resistance
Bending Radius / Setting Radius
IEC 60332-1
IEC 60811-2-1
10 x Diameter / 5 x Diameter
Halogen Free
Maximum Pulling Tension
Temperature Range - Installation
Temperature Range - Operating
IEC 60754-1 / IEC 60754-2 (FRNC and PUR Cable)
80N
-5.0oC to +50.0oC
-40.0oC to +80.0oC
Version 03 (07/10)
4
很抱歉,暂时无法提供与“74001E”相匹配的价格&库存,您可以联系我们找货
