Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
76025WS Multi-Conductor - 300V Foil/Spiral Shield, Continuous Flexing Data Applications Up to 6 Million Flex Life Cycles
For more Information
please call
1-800-Belden1
Description
28 AWG stranded (7x36) tinned copper conductors, PVC insulation, Aluminum/Polyester Foil Shield, Tinned copper spiral shield,
90% coverage, oil-resistant PVC jacket.
Physical Characteristics (Overall):
Conductor:
AWG
# Conductors AWG Stranding Conductor Material
25
28
7x36
TC - Tinned Copper
Insulation:
Insulation Material
Insulation Material
Wall Thickness (in.)
PVC - Polyvinyl Chloride
0.010
Insulation Color Code Chart
Number Color
1
Black
2
Red
3
White
4
Green
5
Orange
6
Blue
7
Brown
8
Yellow
9
Violet
10
Slate
11
Pink
12
Tan
13
Red/Green
14
Red/Yellow
15
Red/Black
16
White/Black
17
White/Red
18
White/Green
19
White/Yellow
White/Blue
21
White/Brown
22
White/Orange
23
White/Slate
24
White/Violet
25
White/Black/Red
Outer Shield:
Outer Shield Material
Layer # Type Outer Shield Material Coverage (%)
1
Tape
Aluminum/Mylar
100.000
2
Serve
TC - Tinned Copper
90.000
Outer Jacket:
Outer Jacket Material
Nom. Wall Thickness (in.)
0.040
Overall Cable:
Overall Nominal Diameter:
0.329 in.
Page 1 of 2
11-29-2017
Mechanical Characteristics (Overall):
Bulk Cable Weight:
66 lbs/1000 ft.
Max. Recommended Pulling Tension:
42 lbs.
Min. Bend Radius/Minor Axis:
2.600 in.
Min. Bend/Installation:
2.600 in.
Min. Bend Radius (Continuous Flexing):
2.600 in.
Flex Cycle Rating
6 Million Flexes
Applicable Specifications and Agency Compliance (Overall):
Applicable Standards & Environmental Programs:
CM
NEC/(UL) Specification
CEC/C(UL) Specification
CMG
EU Directive 2011/65/EU (ROHS II)
Yes
MII Order #39 (China RoHS)
Yes
Customer Part Number Reference Specification
AWM/STYLE 10002, AWM/STYLE 2661, CSA AWM I/II A/B, EU Directive
2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California Proposition 65
Flame Test:
CSA Flame Test
FT4
Suitability:
Suitability - Burial
Yes
Electrical Characteristics (Overall):
Nom. Inductance
Inductance (µH/ft)
0.220
Nom. Capacitance Conductor to Conductor
Freq. (MHz) Capacitance (pF/ft)
0.001
25.000
Nom. Conductor DC Resistance
DCR @ 20°C (Ohm/1000 ft)
67.000
Nominal Outer Shield DC Resistance
3.100
Max. Operating Voltage - UL
Voltage
300V
Notes (Overall):
Notes
Revision Number: 0
Temperature Range -10 to 105°C(static), +5 to 105°C (dynamic)
Revision Date: 09-28-2017
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and
specifications described herein are subject to error or omission and to change without notice, and the listing of such
information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties,
whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect,
incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such
damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use,
or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Page 2 of 2
11-29-2017
很抱歉,暂时无法提供与“76025WS 008100”相匹配的价格&库存,您可以联系我们找货
