Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
76606TS Multi-Conductor - 300V Shielded, Continuous Flexing Data Applications Up to 6 Million FLex Life Cycles
For more Information
please call
1-800-Belden1
General Description:
24 AWG stranded (10x34) tinned copper conductors, PVC insulation, aluminum/polyester foil shield, tinned
copper braid shield, 85% coverage, oil-resistant overall PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material Dia. (in.)
6
24
10x34
TC - Tinned Copper 0.024
Total Number of Conductors:
12
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.) Dia. (in.)
PVC - Polyvinyl Chloride 0.010
0.044
Outer Shield
Outer Shield Material:
Type
Outer Shield Material Coverage (%)
Foil Shield Alum/Mylar
100.000
Braid
85.000
Tinned Copper
Outer Shield Drain Wire AWG:
Component AWG Stranding Drain Wire Conductor Material
Drain Wire
26
7x34
TC - Tinned Copper
Outer Shield Separator Material:
Tissue Tape, 25% Overlap, Min.
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.040
Overall Cable
Overall Nominal Diameter:
0.337 in.
Pair
Pair Color Code Chart:
Number Color
1
BLACK-RED
2
BLACK-WHITE
3
BLACK-GREEN
4
BLACK-BLUE
5
BLACK-BROWN
5
BLACK-YELLOW
Mechanical Characteristics (Overall)
Bulk Cable Weight:
66 lbs/1000 ft.
Max. Recommended Pulling Tension:
46 lbs.
Min. Bend Radius/Minor Axis:
3.370 in.
Min. Bend/Installation:
3.370 in.
Min. Bend Radius (Continuous Flexing):
5.060 in.
Flex Cycle Rating:
6 Million Flexes
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CM
AWM Specification:
UL Style 20006
CSA Specification:
600 V AWM I/II A/B
EU Directive 2011/65/EU (ROHS II):
Yes
Other Specification:
AWM/STYLE 10002, AWM/STYLE 2661, CM, AWM I/II A/B, C(UL) TYPE CMG, FT4, EU Low Voltage
Page 1 of 2
10-02-2017
Directive 2014/35/EC, EU Directive 2011/65/EU(RoHS2)
Flame Test
CSA Flame Test:
FT4
Suitability
Sunlight Resistance:
Yes
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Description
Impedance (Ohm)
Characteristic Impedance 82.000
Nom. Inductance:
Inductance (µH/ft)
0.190
Nom. Capacitance Cond. to Other Cond. & Ground:
Description
Freq. (kHz) Capacitance (pF/ft)
Mutual Capacitance 1.000
23.100
Ground Capacitance 1.000
42.000
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
29.000
Nominal Outer Shield DC Resistance:
2.900
Notes (Overall)
Notes: -10 to 105°C(static), +5 to 105°C (dynamic)
Put Ups and Colors:
Item #
Revision Number: 0
Putup
Ship Weight
Color
Notes
Item Desc
Revision Date: 09-27-2017
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Page 2 of 2
10-02-2017
很抱歉,暂时无法提供与“76606TS 008100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+46.29198100+6.00635
