7792A B591000
7792A B591000
    BELDEN
    12 #23 PE/GIFHDPE SH PVC 1=1000'
7792A B591000 数据手册
Part Number: 7792A VideoFLEX® Snake, Sub-miniature, 12 Coax 23 AWG, Riser Product Description Digital Coax Snake Cable, 12-Sub-miniature 23 AWG, solid bare copper conductors, foam HDPE core, Duofoil® + 95% tinned copper braid, Riser, PVC jacket. Technical Specifications Product Overview Environmental Space: Indoor/Outdoor Physical Characteristics (Overall) Conductor AWG Stranding 23 Solid Material Nominal Diameter No. of Coax BC - Bare Copper 0.023 in 12 Conductor Count: 12 AWG Size: 23 Insulation Material Nominal Diameter Gas-injected FHDPE - Foam High Density Polyethylene 0.102 in Inner Shield Material Type Layer Material Tape 1 Aluminum Foil-Polyester Tape-Aluminum Foil Braid 2 TC - Tinned Copper Material Trade Name Coverage [%] Duofoil® 95 % Inner Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.159 in Outer Shield Material Material Unshielded Outer Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.825 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Inner Shield DCR Outer Conductor DCR 20.1 Ohm/1000ft 7.6 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Shield 16.5 pF/ft Inductance Nominal Inductance 100 % 7.6 Ohm/1000ft 0.106 µH/ft Impedance Nominal Characteristic Impedance 75 Ohm High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.4 dB/100ft 3.6 MHz 0.8 dB/100ft 10 MHz 1.2 dB/100ft 71.5 MHz 3.1 dB/100ft 135 MHz 3.8 dB/100ft 270 MHz 5.4 dB/100ft 360 MHz 6.2 dB/100ft 540 MHz 7.7 dB/100ft 720 MHz 9.1 dB/100ft 750 MHz 9.5 dB/100ft 1000 MHz 10.5 dB/100ft 1500 MHz 13 dB/100ft 2500 MHz 16.9 dB/100ft 3000 MHz 18.5 dB/100ft 4500 MHz 24.6 dB/100ft 6000 MHz 28.97 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.24 ns/ft 83 % Voltage UL Voltage Rating 300 V RMS Temperature Range Non-UL Temp Rating: 75°C UL Temp Rating: 60°C Operating Temp Range: -35°C To +75°C Mechanical Characteristics Bulk Cable Weight: 310 lbs/1000ft Max Recommended Pulling Tension: 432 lbs Min Bend Radius/Minor Axis: 8.5 in Standards NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG CPR Euroclass: Eca RG Type: Mini RG-59/U Type Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1666 Vertical Shaft CSA Flammability: FT4 Part Number Plenum (Y/N): No Suggested Connectors: Kings 2065-11-9 75 Ohm BNC, each coax Footnote: C - CRATE REEL PUT-UP. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
7792A B591000 价格&库存
很抱歉,暂时无法提供与“7792A B591000”相匹配的价格&库存,您可以联系我们找货
