7852A D15A1000
7852A D15A1000
    BELDEN
    CAT6E+ 4PRB U/UTP CMP RIB
7852A D15A1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7852A Multi-Conductor - Enhanced Category 6 Bonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT6+ (600MHz), 4-Bonded-Pairs, U/UTP-Unshielded, Plenum-CMP, Premise Horizontal Cable, 23 AWG Solid Bare Copper Conductors,FEP Insulation, Patented E-Spline, Ripcord, Flamarrest® Jacket Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, POE, POE+,100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU Digital Audio, AES51, RS-422, Noisy Environments Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 23 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material FEP - Fluorinated Ethylene Propylene Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® LS PVC - Low Smoke Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.255 Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Separator Material: Patented E-Spline Center Member Overall Nominal Diameter: 0.218 x 0.290 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Storage Temperature Range: -20°C To +75°C Installation Temperature Range: +5°C To +50°C Operating Temperature Range: 0°C To +75°C Bulk Cable Weight: 37 lbs/1000 ft. Max. Recommended Pulling Tension: 45 lbs. Min. Bend Radius/Minor Axis: 0.500 in. Min. Bend/Installation: 2.250 in. Page 1 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7852A Multi-Conductor - Enhanced Category 6 Bonded-Pair Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP NEC Articles: 800 CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2006 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 6 - TIA 568.C.2 Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: NFPA 262 Plenum Flame Test (UL910)(FT6) C(UL) Flame Test: FT6 CSA Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 7851A Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15.5 Maximum Capacitance Unbalance (pF/100 m): 90 Nominal Velocity of Propagation: VP (%) 67 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 38 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 8.2 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) 1 1.900 82.3 80.3 80.5 78.5 20.000 4 3.600 73.3 71.3 69.7 67.7 23.000 8 5.100 68.8 66.8 63.7 61.7 24.500 Page 2 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7852A Multi-Conductor - Enhanced Category 6 Bonded-Pair Cable 10 5.700 67.3 65.3 61.6 59.6 25.000 16 7.200 64.3 62.3 57.0 55.0 25.000 20 8.100 62.8 60.8 54.7 52.7 25.000 25 9.100 61.3 59.3 52.3 50.3 25.000 31.25 10.200 59.9 57.9 49.7 47.7 25.000 62.5 14.700 55.4 53.4 40.7 38.7 25.000 100 18.900 52.3 50.3 33.4 31.4 25.000 155 23.900 49.5 47.5 25.5 23.5 22.800 200 27.500 47.8 45.8 20.3 18.3 21.600 250 31.200 46.3 44.3 15.2 13.2 20.500 300 34.500 43.2 43.2 8.6 8.6 20.200 350 37.700 42.1 42.1 4.4 4.4 19.800 400 40.600 41.3 41.3 0.7 0.7 19.500 450 43.500 40.5 40.5 0 0 18.900 460 44.000 40.4 40.4 0 0 18.800 500 46.200 39.8 39.8 18.400 550 48.800 39.2 39.2 18.000 600 51.400 38.6 38.6 17.600 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ACRF (dB) Min. PSACRF (dB) 1 100 ± 12 100 ± 15 74.8 72.8 4 100 ± 12 100 ± 10.4 62.8 60.8 8 100 ± 12 100 ± 8 56.7 54.7 10 100 ± 12 100 ± 7.3 54.8 52.8 16 100 ± 12 100 ± 5.7 50.7 48.7 20 100 ± 12 100 ± 5 48.8 46.8 25 100 ± 15 100 ± 5 46.8 44.8 31.25 100 ± 15 100 ± 5 44.9 42.9 62.5 100 ± 15 100 ± 5 38.9 36.9 100 100 ± 15 100 ± 5 34.8 32.8 155 100 ± 15 100 ± 5 31.0 29.0 200 100 ± 15 100 ± 5 28.8 26.8 250 100 ± 20 100 ± 5 26.8 24.8 300 100 ± 20 100 ± 5 25.3 23.3 350 100 ± 22 100 ± 5 23.9 21.9 400 100 ± 22 100 ± 5 22.8 20.8 450 100 ± 22 100 ± 5 21.7 19.7 460 100 ± 22 100 ± 5 21.5 19.5 500 100 ± 22 100 ± 5 20.8 18.8 550 100 ± 22 100 ± 5 20.0 18.0 600 100 ± 22 100 ± 5 19.2 17.2 Notes (Overall) Notes: Belden IBDN. Jacket sequentially marked at 2 ft./1m intervals. Third party verified to ANSI/TIA-568-C.2, Category 6. Put Ups and Colors: Item # Putup Ship Weight Color 7852A D15A1000 1,000 FT 44.000 LB BLUE Notes Item Desc 7852A D151000 1,000 FT 41.000 LB BLUE 7852A 0021000 1,000 FT 41.000 LB RED 7852A 003A1000 1,000 FT 44.000 LB ORANGE C CAT6E+ 4PRB U/UTP CMP RIB 7852A 0031000 1,000 FT 41.000 LB ORANGE C CAT6E+ 4PRB U/UTP CMP REEL 7852A 004A1000 1,000 FT 44.000 LB YELLOW 7852A 0041000 1,000 FT 41.000 LB YELLOW 7852A 005A1000 1,000 FT 44.000 LB GREEN, DARK 7852A 0051000 1,000 FT 41.000 LB GREEN, DARK 7852A 008A1000 1,000 FT 44.000 LB GRAY CAT6E+ 4PRB U/UTP CMP RIB 7852A 0081000 1,000 FT 41.000 LB GRAY CAT6E+ 4PRB U/UTP CMP REEL 7852A 009A1000 1,000 FT 44.000 LB WHITE 7852A 0091000 1,000 FT 41.000 LB WHITE 7852A 0101000 1,000 FT 41.000 LB BLACK CAT6E+ 4PRB U/UTP CMP RIB C CAT6E+ 4PRB U/UTP CMP REEL CAT6E+ 4PRB U/UTP CMP REEL CAT6E+ 4PRB U/UTP CMP RIB C CAT6E+ 4PRB U/UTP CMP REEL CAT6E+ 4PRB U/UTP CMP RIB C CAT6E+ 4PRB U/UTP CMP REEL CAT6E+ 4PRB U/UTP CMP RIB C CAT6E+ 4PRB U/UTP CMP REEL CAT6E+ 4PRB U/UTP CMP REEL Notes: C = CRATE REEL PUT-UP. Page 3 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7852A Multi-Conductor - Enhanced Category 6 Bonded-Pair Cable Revision Number: 9 Revision Date: 06-09-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 4 of 4 02-01-2017
7852A D15A1000 价格&库存
很抱歉,暂时无法提供与“7852A D15A1000”相匹配的价格&库存,您可以联系我们找货
