Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
9244 Coax - 75 Ohm Coax
For more Information
please call
1-800-Belden1
General Description:
22 AWG solid bare copper-covered steel conductor, polyehtylene insulation, bare copper braid shield (85%
coverage), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
22
Solid
Dia. (in.)
BCCS - Bare Copper Covered Steel .025
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material Dia. (in.)
PE - Polyethylene
.146
Outer Shield
Outer Shield Material:
Type Outer Shield Material Coverage (%)
Braid BC - Bare Copper
85
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Overall Cable
Overall Nominal Diameter:
0.242 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +80°C
Non-UL Temperature Rating:
80°C
Bulk Cable Weight:
33 lbs/1000 ft.
Max. Recommended Pulling Tension:
67 lbs.
Min. Bend Radius/Minor Axis:
2.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMX
CEC/C(UL) Specification:
CMX
AWM Specification:
UL Style 1354 (30 V 80°C)
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
59/U
Page 1 of 3
01-05-2017
Flame Test
UL Flame Test:
VW-1
Suitability
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
75
Nom. Inductance:
Inductance (µH/ft)
.112
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
19.4
Nominal Velocity of Propagation:
VP (%)
66
Nominal Delay:
Delay (ns/ft)
1.54
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
50
Nominal Outer Shield DC Resistance:
4.5
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1
.6
10
1.1
50
2.4
100
3.4
200
4.9
400
7.0
700
9.7
900
11.1
1000
12.0
Nom. Power Rating:
Freq. (MHz) Rating (W)
50
470
100
310
300
160
500
115
1000
76
Max. Operating Voltage - UL:
Voltage
150 V RMS
Max. Operating Voltage - Non-UL:
Voltage
1700 V RMS
Minimum Return Loss:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB)
5
450
23
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
9244 010U1000
1,000 FT
35.000 LB
BLACK
Page 2 of 3
Notes
Item Desc
RG-59/U TYPE COAX
01-05-2017
9244 010U500
500 FT
18.000 LB
BLACK
RG-59/U TYPE COAX
9244 0101000
1,000 FT
36.000 LB
BLACK
RG-59/U TYPE COAX
Revision Number: 3
Revision Date: 05-14-2007
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“9244 010U1000”相匹配的价格&库存,您可以联系我们找货
