9342 010500
9342 010500
    BELDEN
    CBL 1PR 16AWG SHLD
9342 010500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9342 Multi-Conductor - 600V Tray Cable For more Information please call 1-800-Belden1 General Description: 16 AWG pairs stranded (19x29) tinned copper conductors, twisted pairs, PVC/Nylon insulation, overall Beldfoil® shield (100% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 1 16 19x29 TC - Tinned Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material PVC/Nylon - Polyvinyl Chloride/Nylon Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 16 19x29 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.047 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.294 in. Pair Pair Color Code Chart: Number Color 1 Black & Red Mechanical Characteristics (Overall) Wet Temperature Range: -30°C To +75°C Dry Temperature Range: -30°C To +90°C Bulk Cable Weight: 56 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: NPLF, TC EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9342 Multi-Conductor - 600V Tray Cable CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: ICEA S-73-532, S-61-402 Flame Test UL Flame Test: UL1685 UL Loading C(UL) Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Burial: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .20 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 50 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 87 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.200 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.200 Max. Operating Voltage - UL: Voltage 600 V RMS (NEC Type TC) 150 V RMS (NPLF) Max. Recommended Current: Current 8 Amps per conductor @ 30°C Notes (Overall) Notes: Alternate color coding available upon request. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9342 0101000 1,000 FT 55.000 LB BLACK C 2 #16 PVC/NYL SHLD PVC 9342 01010000 10,000 FT 630.000 LB BLACK 9342 010500 500 FT 27.500 LB BLACK 9342 0105000 5,000 FT 300.000 LB BLACK 2 #16 PVC/NYL SH PVC C 2 #16 PVC/NYL SHLD PVC 2 #16 PVC/NYL SHLD PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-07-2014 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9342 Multi-Conductor - 600V Tray Cable Page 3 of 3 08-26-2016
9342 010500 价格&库存
很抱歉,暂时无法提供与“9342 010500”相匹配的价格&库存,您可以联系我们找货
