9550 060500
9550 060500
    BELDEN
    CBL 50PR 24AWG SHLD
9550 060500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9550 Multi-Conductor - Computer Cable for EIA RS-232 Applications For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (7x32) TC conductors, semi-rigid PVC insulation, twisted pairs, overall Beldfoil shield (100% coverage), 24 AWG stranded TC drain Wire (continued), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 50 24 7x32 TC - Tinned Copper Total Number of Conductors: 100 Insulation Insulation Material: Insulation Material Wall Thickness (in.) S-R PVC - Semi-Rigid Polyvinyl Chloride 0.011 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape w/Shorting Fold 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.054 Overall Cable Overall Nominal Diameter: 0.708 in. Pair Pair Color Code Chart: Number Color 1 Blue & White 2 Orange & White 3 Green & White 4 Brown & White 5 Gray & White 6 Blue/ White & White 7 Blue/Orange & White 8 Blue/Green & White 9 Blue/Brown & White 10 Blue/Gray & White 11 Orange/White & White 12 Orange/Green & White 13 Orange/Brown & White 14 Orange/Gray & White 15 Green/White & White 16 Green/Brown & White 17 Green/Gray & White 18 Brown/White & White 19 Brown/Gray & White 20 Gray/White & White 21 Blue & Red 22 Orange & Red 23 Green & Red 24 Brown & Red Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9550 Multi-Conductor - Computer Cable for EIA RS-232 Applications 25 Gray & Red 26 Blue/White & Red 27 Blue/Orange & Red 28 Blue/Green & Red 29 Blue/Brown & Red 30 Blue/Gray & Red 31 Orange/White & Red 32 Orange/Green & Red 33 Orange/Brown & Red 34 Orange/Gray & Red 35 Green/White & Red 36 Green/Brown, Red 37 Green/Gray & Red 38 Brown/White & Red 39 Brown/Gray & Red 40 Gray/White & Red 41 Blue & Black 42 Orange & Black 43 Green & Black 44 Brown & Black 45 Gray & Black 46 Blue/White & Black 47 Blue/Orange & Black 48 Blue/Green & Black 49 Blue/Brown & Black 50 Blue/Gray & Black Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +80°C Non-UL Temperature Rating: 80°C (UL AWM Style 2464) Bulk Cable Weight: 286 lbs/1000 ft. Max. Recommended Pulling Tension: 550 lbs. Min. Bend Radius/Minor Axis: 7.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG AWM Specification: UL Style 2464 (300 V 80°C) CSA Specification: AWM I A EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 FT4 Loading C(UL) Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 30 Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9550 Multi-Conductor - Computer Cable for EIA RS-232 Applications Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 50 Nominal Velocity of Propagation: VP (%) 60 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 24 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.2 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 1.1 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9550 060100 100 FT 31.900 LB CHROME C 50 PR #24 PVC FS PVC 9550 0601000 1,000 FT 311.000 LB CHROME CD 50 PR #24 PVC FS PVC 9550 060500 500 FT 162.000 LB CHROME CD 50 PR #24 PVC FS PVC Notes: C = CRATE REEL PUT-UP. D = FINAL PUT-UP LENGTH MAY VARY -0% TO +20% FROM LENGTH SHOWN. Revision Number: 2 Revision Date: 08-31-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9550 060500 价格&库存
很抱歉,暂时无法提供与“9550 060500”相匹配的价格&库存,您可以联系我们找货
